Intermittent semi-rough idle. Hesitant vibration around 57-60MPH
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Hello all,
I have an 02 Type S with 160,000 miles. It will idle semi rough (slight but not troublesome vibration) when coming to a stop at intermittent times. It will also, almost every time, have heavy vibration (feels like its not getting fuel) around 57-60 MPH. This vibration at idle also happens in neutral as well and the 57-60 MPH vibration in any selectable gear for that range. Otherwise at every other speed except randomly sometimes at idle it performs flawlessly. ECU has recorded no codes. I have replaced plugs and air filter. I have not replaced the fuel filter, does this sound typical of a clogged filter on this machine? Could there be an odd vacuum or emissions control problem i am overlooking? Thanks for your help in advance.
Jesse
Jesse
Check your motor mounts.
Passenger side and Front. These mounts have a typical life span of 50k or so.
This thread has a little info on what to look for and how to quick test the front one
https://acurazine.com/forums/2g-tl-problems-fixes-117/when-replace-motor-mount-609085/
MrHeeltoe
20
02-23-2023 01:54 PM
acuratl26
04-23-2020 07:30 PM
joflewbyu2
10-08-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
