How should i fix my ugly pillars?
Well everytime i head into my car, i see those ugly pillars where some parts of it has that shiny gloss to it and some parts doesnt, is there a way to recoat it or replace it? i saw 03tlsnbp's plastidip ones and they looked good. should i do this?
Unregistered Member
http://www.soaap.com/auto/images/pro...AP-MM-2181.jpg
You mean the B pillars in that picture? I also would like a solution, as mine are in poor condition (sun damage?).
I might ask the bodyshop im getting my hood repainted at how much it would be to paint the pillars NBP. Body colored pillars might be nice...
Original Owner / Oct 1998
I considered painting the plastic...but it is actually deteriorating, becoming crazed from within. I didn't think the paint would last after a few more years of freeze/thaw/UV sunlight.
MechEng
you could try the vinyl that ^ posted or if you dont mind spending a little more, you could go with 3M gloss vinyl.
or you dont mind the matte black look you can do plasti-dip.
orrr if you have the funds you can get a body shop to paint them black. but do not paint them body color if you have anything other than NBP. it will look terrible.
MechEng
i heard somewhere that they make a gloss plasti-dip. i havent seen it any stores but maybe they sell it online
MechEng
i didnt take off the pillars. i just wet sanded them down so they were smooth and cleaned them with acetone. any overspray can be peeled/rubbed off with your fingers or a towel.
i sprayed on 2 coats. about 10-15 minutes between coats. thats about it.
^lmaoooo
aite. REAL solution, not hard, clean, permenant. follow the diy to remove ur pillars. go to autozone or auto store and pick up duplicolor trim paint. THEY HAVE HONDA NBP!!!! use high grit sand paper, meaning 400, sand off old shiney coat, take grit up to 600 or even 800 to smooth out. then spray like 5-6 coats of paint, then spray 8-10 coats of clear. give each coat AT LEAST 15mins to dry b4 adding another. this is not hard by any means! only trouble i had was dropping the stupid screws into the door because i am a klutz. result is clean and dam near close to factory look. the only way you would be able to tell is if you had them side by side to compare.
Why would you NOT take the 5 min to take them all off and sand them and paint them OFF the car making a better paint job with NO overspray???????
^lmaoooo
mlody
12-04-2019 02:11 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
