How do you install an "Oil Filter Holder"?
Old 10-19-2018, 02:33 PM
Randin Dragonheart's Avatar
Question How do you install an "Oil Filter Holder"?
TLDR: How do you install an oil filter holder that doesn't have a hex shape in the middle to fit a socket?
I was changing the oil in my '00 TL and appear to have over-tightened the oil filter because it continually spun like a screw into drywall with no stud. Believing I stripped the threads, I ordered part 21 from here: acuraoemparts oil pump/strainer. Most oil filter holders I've seen have a hex shape in the middle that you can fit a socket onto, but this one does not. Not knowing how to install it, i wrapped it in a cloth and used channel locks to tighten it in. Well that completely demolished the threads. I ordered a replacement piece, but still have no idea how to install. Are there any tricks to this or do i need special tool? At a loss here =/
Before and After Eek!
Before and After
Thanks in advance for the help
Randin!
Old 10-19-2018, 03:36 PM
Received 8,582 Likes on 6,629 Posts
and internal pipe wrench would really help you out
https://www.homedepot.com/p/General-...39-4/301371197
Old 10-19-2018, 04:30 PM
Killer! Thanks for the tip!
Old 10-20-2018, 06:50 PM
wng
wng's Avatar
thoiboi, as usual, has the best answer. I'm wondering, however, if the hardware stores are closed and you really need to put in the filter immediately, you could hand tighten the filter to the holder FIRST, then screw the entire thing into the valve assembly. By tightening the oil filter (I like to use those handles with a rubber strap), it'll also tighten the filter holder to the assembly. Likely when you unscrew it later, the holder will come out with the filter, though. Crazy, or would it work?
Ron A (10-20-2018)
Skirmich
09-12-2018 09:29 PM
intelliboy
01-21-2007 03:16 PM
willang
05-04-2002 07:20 AM
hdp203
12-21-2001 03:05 PM
[VTEC]TL
11-18-2001 08:03 PM
Quick Reply: How do you install an "Oil Filter Holder"?
