How to diagnosing Front window/door Wind Noise?
So I'm starting to hear wind noise from my driver door or window. I'm not sure how I can pinpoint where the noise is coming from ( I think it's coming from the left top corner of the window/door). It almost sounds like if I had my window opened about an inch but it's not.
I've tried cleaning my door seals with some 303 protectant but the wind noise still persits.
How can I tell if I have a bad seal from somewhere? And turning up the music is not an option so any tips or guidance would be greatly appreciated.
Lastly anyone know the part number for the door seal and if it's easy to change out?
I think the first suggestion 014tl made is the way...get a good detailing and see if you can get the lustre back. About wind noise...look into ordering some shin etsu grease from handaaccessories(dot)com to bring the seal back to your door seals. I found this helped a lot with killing the wind noise from highway driving. Also, you can take off your door panels and put on some 50 to 80 mil sound deadener (also will make the music sound better). That should help too.
Good luck!
Good luck!
rockyboy
01-25-2016 06:00 PM
