High-pitched whining/humming noise - 02 Type S
As the title states, I've been getting a consistent high-pitched humming/whining noise. Originally I thought it was my power steering, but after listening to it closer it seems as if its definitely coming from the engine - lower left side possibly. The sound heightens and lowers as I accelerate or rev in neutral. Sometimes the noise isn't there on startup, sometimes it is. Transmission was replaced 25k miles ago, don't think it has anything to do with that - been shifting/running fine.
Thoughts? Oil pump maybe?
spend 5 bucks on a mechanics stethascope
put end tip on suspect bearings or other areas
touch to main solid section of ac belt tensioner- not the moving parts
listen for smooth rythmic= good or gravel = bad
snorf
11-04-2019 06:44 AM
