Hesitationg during idle
Bahito
2000 3.2TL
Purchased recently. After two weeks the check engine light came on. With the CEL's: Misfire cylinders 1-5. And Random Misfire"
-I bought 6 brand new oem spark plugs from acura
- I bought 6 brand new coil packs from acura
After installing the new coil packs (disconnected the battery, so that would reset the ECU right?) No check engine light was present. Everything seemed fine until a few minutes later. The car was @ idle the whole time. When the check engine light was flashin slowly. Then stayed solid. I turned off the car then turned it back on. No check engine like was present. But the car idles rough/hesitates. If I rev the motor past 2,000rpm's it feels smoother but anything below or @ idle it feels rough.
Any ideas why the idle is rough? I didn't want to drive the car around like that but when I moved foward or reverse it has a harsh hesitation under throttle. But no CEL present.
Bahito
Bump because im F*ckin pissed @ this damn car!
Common People, I've already seen multiple threads with the same issue. Has no one fixed this problem?
People have said it could be: Coil packs, spark plugs, EGR valves.
even bent valves..<--- that I do not believe. I've built 200+ hp four cyl honda motors, and i've bent valves before...Trust me when you bent a valve the car will not run correctly @ all. this issue is just during 2,000rpms and under apparently....
my friend works @ Acura\honda... He looked into their online service bulletins and told me the coil pack was the issue.. now lets see what he says this afternoon. Until then I just want to know if anyone else with this issue has finally had it resolved??????
Bahito
mah nikka..or should i say bro. if you want to contribute.. do so.. i dont need ur useless comments just so you can get your post count up.. i could care less...
I've searched the web and i see alot of TL owners with this issue.. and every single thread in different forums have no answers.. just people who "think" they know. I'm just looking for someone that had the issue, and knows what the answer is to fix it.
I need this car fixed asap to get to work.
spark plugs or coil related.
Get new plugs and buy one replacement coil. Swap it out the new coil for one used and rotate until you get rid of the problem. It's very rare more then one coil has failed you.
Bahito
all from Acura
The CEL didn not come on again.. so maybe its having more than one issue???? brand new coils and spark plugs.. EGR valve maybe?
But I thought EGR issues are under throttle.. not idle.. When you give the car gas the EGR valve should close.. if it is dirty or not working it will stay open.. If its not that.. im stumped
ok- what the most likely problem really was : 1 bad coil AND the egr PORTS inside the intake manifold still need to be cleaned!
See DIY section - Thermoblock install and EGR cleaning-
Its not the EGR valve- but the ports inside the manifold that get plugged about
every 75k miles.
Im sure no one here said to buy 6 coils!!!- we always tell people that multi misfire codes is often 1 coil, and to buy one and start trying it on each cylinder
Codes are clues not diagnosis~
yes battery NEG cable disconnect will reset the ECU
every 75k miles.
some engine cleaning treatment- bg44-wynss-seafoam etc, will help you start from clean in the diagnosing, and make the injectors spray right-
I like redline SI-1 fuel cleaner in 1/2 tank of gas
Have you had the codes read at an auto parts store?
or did you decide it needed plugs and all new coils based on internet reading?
Get it slowly to autozone type store and they will do it for free
whats the cars current mileage?
Bahito
every 75k miles.
every 75k miles.
The car has 100k
No one told me to get all 6. i just like to do preventative maintanence, so situations like this wont happen again.(starter motor,alternator next)
Yeah hopefully that will do it, my friend said he was gonna bring me a can from the dealer. and i'll check out that SI-1 out.
before changing the coils it was :
P0300 = MULTIPLE CYLINDER MISFIRE
P0301 = P0306 = MISFIRE ON PISTON 1-6
I first went to him, then looked online to see other peoples experiences.
bringin lead
i just spend $120 on the spark plugs and $340 on the coils
all from Acura
all from Acura
I feel like we're missing some details here. Have you had any work done recently? What's changed? Are you burning oil? Have you done the 105K service? Who did your valves? Have you run any cleaners through the car recently? Is the car warm when you have these problems?
Bahito
Well I would have spent $80 to get here, so I can't help you with your $340.
I changed:
-Battery
-Air filter
-Cabin Air filter
-spark plugs
-oil change
-coil packs
-starter motor
-springs & shocks
-and did an alignment
the problem happens when the car is warmed up.
i doubt the previous owner had the 105k service done.
I'm gonna have my friend from Acura do the timing belt\water pump\valves done in january or feb. 09'
PS: I got the dealer i bought the car from to pay for all 6 coil packs and a starter motor
Bahito
I just bought the car less than one month ago.
I changed:
-Battery
-Air filter
-Cabin Air filter
-spark plugs
-oil change
-coil packs
-starter motor
-springs & shocks
PS: I got the dealer i bought the car from to pay for all 6 coil packs and a starter motor![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
I changed:
-Battery
-Air filter
-Cabin Air filter
-spark plugs
-oil change
-coil packs
-starter motor
-springs & shocks
I like the techron one. I put the treats up to 25Gal in my tank, and do two tanks back to back.
You are due for your 105K service, you may notice the improvements after that. Its unlikely your fuel filter as they last a lot longer then 100K
Stop. You need to learn not to take your anger out on the people that will help you. So your car isn't perfect, get over it. No sense getting all excited with the speed, or lack thereof a FREE forum.
Want the problem fixed quickly? Go pay for such a service, at a mechanic. The rest of us here share our knowledge and experience on our own time not yours.
Remember that the next time you snap at someone.
Bahito
Its unlikely but your valves might be slightly off. Mine were, and I noticed an improvement on how the motor felt. Mostly that is was smoother and a little more power. Your Throttle body might need a cleaning as well. This improved my responsiveness at low RPMs. TB is easy to clean and can be done either at your 105K service when you'll have access to it or now. Also if you want to drop $4-5 on injector cleaners I'd try a few back to back.
Well I have replaced:
-spark plugs
-coil packs
-Egr valve
-cleaned the TB and removed the intake manifold and cleaned it.
it still hesitating during idle and now hesitating during acceleration.
So this is something I jus stumbled upon.
Misfire's can cause a catalytic converter to go bad\clogged.
So the spark plug\coil that i replaced that had caused a mis fire seems to have clogged up my cat. I am not sure but tomorrow i will lift up the car and take a look into the cat to see if thats what it really is.
many sites on the internet said:
Here are just a few of the signs and symptoms of a plugged/dead cat:
- Markedly decreased low rpm power,
- Engine runs a little hotter than normal at constant cruising speeds,
- Exhaust leaks near header that won't seal in spite of new gaskets,
- Bucking or hesitation while accelerating,
- Cat's exterior surface temp cooler near outlet.
-spark plugs
-coil packs
-Egr valve
-spark plugs
-coil packs
-Egr valve
You never mentioned you removed the manifold.
Are you certain the intake manifold was put back on properly? Are all your sensors plugged back in properly?
Was it tightened back up evenly? Did you problems start shortly after you did your work? If it's not sealed properly this could cause your idling and throttle issues.
Frankly, I'd be taking it to a shop to have them look at it. Too many details missing on this story to be very helpful.
Bahito
bringin lead
Bahito
Bahito
I wont be helping you any further. Goodwill on my part only goes to far. Then you go and act like a child. Bad behavior is not acceptable on this forum.
If you come back drop the attitude - your problems are bigger then this forum. As for your car, the dealership looks like a very good option.
Ackniculous One
![](http://www.cyburbia.org/gallery/data/500/rodney_king.jpg)
LMAO
Yeah man, I suspect you have some buildup that needs to be cleaned and run some seafoam to see if that helps, I think Tom (01tl4tl) has a good diagnosis on your problem.
I would also advise you that this forum is invaluable for information and as long as you respect it and the members, you will see just how much people will help you. Plus, its the holidays so the board isn't near as active right now as it usually is with folks on vacation and stuff...so relax, the information will lead you to a solution, trust me.
bringin lead
^^hahahaha!
as was mentioned in earlier posts, respect for other members is invaluable here! show it and help will flow your way - act as you have with the 3rd grade responses and nobody cares enough about your problems to help out.........
maybe next time you'll heed advice from regulars.
returning now to diagnosing:
A muffler shop can test the cat for temp, flow, plugging- usually at no charge
Cats are warrantied to 8/80, if its failed now, some good aftermarket ones are available from Excelerate, a trusted vendor here- they go for $100 basicto $300 for the performance one iirc
Beats the dealer by several hundred on this part!
*walks in thread, sees gang bang in process, walks out*
DerrickW
11-15-2015 05:52 PM
