Headlights
-Arsenic-
Headlights
Did someone on here say they bought the aftermarket replacement headlights and the visibilty wasn't as good? Worse cut-off maybe? I am trying something and I need new headlights, but the OEM ones are double the cost of aftermarket..
i have the blacked out housings on my 01 from a large seller of housings on the bay
DOT certified- all the mounts matched perfect and the lighting is fine.
Different bulbs make the big changes for you
Kaixen 5000 will give near OE color and white levels
while 6000 will give more blue and pick up road signs and markings better IMO
If your housings are just clouded on the outside- not leaking inside, a bottle of plastic polish and a powerball will make them like new
-Arsenic-
I'm doing something a lil differen't and I want it new, so I guess its safe to go aftermarket?
the ones I got are marked DOT and have all the right numbers on them and fit perfect and work fine. Looks really good too~
send me a link to what you found and I will let you know if same brand/seller
AmplifiedDetails
09-24-2015 02:55 PM
