Gas Smell...
Gas Smell...
I am getting a strong gas smell on the outside of the car when I open my door after I turn it off...It used to be not that strong, but now it's very noticeable. How do I check for leaks? How do I check if the charcoal canister it's full? And what if it is full? Is that like a part you replace or can it be "cleaned"?
B A N N E D
and to repair it, you just replace it and stop clicky, clicky it
it could also be a fuel leak somewhere too idk, a easy way to find it is to go along the fuel line with a lighter, and when it goes you found the leak
Have you recently topped your tank off
LMAO friesm!!
I used to go clicky clicky before, but I stopped doing that after I joined here about a year ago.
Kris, the tank was nearly empty the last time I noticed, but before that it hadn't ocurred to me to see how full the tank was when I noticed the smell.
BTW, where is this canister located?
Thanks again...still laughing!
B A N N E D
LMAO friesm!!
but anyways the canister is underneth on the driver side right in front of the gas tank (rear driver side passenger is sitting right above it)
