FYI -- For those who have oil leaks
B93P TL Owner
I finally got around to fixing an oil leak I've had on my car for the past several months. For anyone who has a leak originating from around the oil filter housing area #12 (and seeping down to the underside of oil pan), take a good look at item #13. It is the VTEC solenoid valve filter (rubber gasket with a filter screen in the center), and this was my culprit. Takes less than thirty minutes to replace but of course you have to drain the oil first, as the filter housing is attached to the block.
#013 15825-P8A-A01 FILTER, SPOOL VALVE
IBankMouse
06-13-2020 12:53 PM
acuratl26
04-23-2020 07:30 PM
