Front brake caliper bracket stripped - need one for a 2002 Acura TL-S
Old 07-02-2009, 09:54 PM
3rd Gear
garyhgaryh's Avatar
I was changing brakes and rotors for a friend of mine with a 2002 Acura TL-S. It was getting dark and I decided I need to rush so I set my impact wrench to full power and stripped both the bolts (those short and fat M12 bolts) that go into the caliper brackets and sandwiches it to the hub assembly. The caliper bracket holds the actual caliper piston assembly and bolts to the hub. Does anyone have a caliper bracket for sale (or the entire caliper assembly) for the front driver's side?
Are the TL and TL-s calipers and/or caliper brackets the same?
Thanks,
Gary
Old 07-02-2009, 10:41 PM
'13 Hyundai Sonata
TLin401's Avatar
Check local salvage yards around your area.
Use this site partshotlines.com.
Old 07-02-2009, 10:51 PM
Thread Police Chief
adamlee05's Avatar
You could drill and re-tap, but although i'm sure itd be safe, I know you wouldnt want to do that.
Here's the entire thing for you:
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Part 7, $72.81. I'm assuming you're talking about part 17 when you mention the M12 bolts.
Rockauto has a few ACDELCO reman'ed brackets, front left.
Old 07-03-2009, 02:12 AM
3rd Gear
garyhgaryh's Avatar
Thanks, althought I don't feel like wasting a few hrs at the junkyard. I'll check the site.
Adam, thanks.. I saw that diagram, but I didn't think part 7 was it.. Looking closely, I believe this is it.
I also looked at rockauto and I only see the rear caliper brackets. where do you see front ones? (link)
Thanks you guys are great.
Some guy on craigs list wants to sell me a used pair for $150. I guess he doesn't know you can buy rebuilt ones with the bracket for $60 plus core charge.
Gary
Old 07-03-2009, 04:44 AM
Thread Police Chief
adamlee05's Avatar
http://www.rockauto.com/catalog/rafr...1377019k417482
Go up to "Caliper" and expand. scroll down until you find:
ACDELCO Part # 18FR1844 More Info {#19141886}
CALIPER,FRT BRK(W/O BRK PADS-REMAN) DURASTOP; RIGHT HAND; FRICTION READY
Price:
$74.79
Core:
$26.40
Total:
$101.19
For the price you should just buy the reman'ed one I linked form acuraoemparts.com
Old 07-03-2009, 03:36 PM
3rd Gear
garyhgaryh's Avatar
Price:
$74.79
Core:
$26.40
Total:
$101.19
This is weird, when I look it up, I only see the rear right and rear left. When I click on your link, i see the same item, but it doesn't mention front or rear.
10.67 is a good price, but I'm not sure it's for the front.
Gary
Old 07-03-2009, 08:53 PM
Thread Police Chief
adamlee05's Avatar
No man, read what i wrote. click the link then in the menu tree, click "CALIPER", not "caliper bracket". Then scroll down and you will find EXACTLY what i posted. It is the 30'th item under the "CALIPER" list.
Old 07-06-2009, 01:08 PM
smartypants's Avatar
Hi Gary :
I did exactly the same thing.
It turns out the stripped out metric hole is exactly the right size to tap a 1/2" imperial fine thread. I took my bracket to a machine shop and had it drilled and tapped for $20. Some day, I'll change out the bracket and put it back to standard, but in the meantime this solution worked great.
I found that you needed to buy the whole caliper (~$150) and they may not give you the core refund ($75) due to the damaged casting.
smartypants
Old 07-30-2009, 03:56 PM
NBP
Skeete32's Avatar
the same thing happened 2 me but I think I can get mine 4 $60 if they know what im talking about. make sure you get the right one tl and type s are different shape.. that pic is wrong if im correct you don't need the cylinder part just the part the short bolts go in right?
Old 07-30-2009, 09:07 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
There should be NO difference in the TL to TL-S. They use the same brake.
Just have yours tapped out (or even cheaper buy the tap yourself and retap it and get the correct English Grade 8 bolt.
Old 09-25-2018, 01:55 AM
sysuleman's Avatar
I know this is an old thread but I just had this issue yesterday so I thought I'd post my fix. You don't need to replace the actual caliper just the bracket that bolts to the steering knuckle. Don't think Acura will sell you just the bracket but you can get it at the Pick-n-Pull for $15.99. The whole caliper at the PnP is $19.99 + $3 core charge but who wants to mess with disconnecting brake lines if you don't have to?
Old 10-02-2018, 09:57 PM
Summitdigs's Avatar
I have an entire 02 TL type S I'm parting out, hot me up and let me know if your still looking
Old 10-05-2018, 10:59 PM
SuperGreg's Avatar
I stripped my caliper bracket due to a torque wrench being out of spec, and replaced it at O'Reilly. Can't remember the price but it was pretty cheap. Can't beat the speed of just driving to the store and picking it up either .
iesu3423
09-29-2015 08:04 AM
theinsvnity
09-10-2015 10:22 PM
HOWELLiNC
09-10-2015 01:39 PM
asahrts
09-04-2015 05:55 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Front brake caliper bracket stripped - need one for a 2002 Acura TL-S
