foglight problem.
Old Mar 21, 2010 | 10:15 PM
kp4lyfx's Avatar
Exclamation foglight problem.
hey guys, so i just installed my HID fogs and i have a problem. when i first installed it, my right side worked and my left side didn't. so i thought it was the ballast and tried switching the ballasts with the left and right one. but it actually worked only on the right side. so the problem wasn't the ballast. i also tried switching the chord that connects the ballast and the fog wires on the car and that was not the problem either because my right side still came on but not my left side. so i tried switching the bulbs also and it still worked on the right side and not the left. does anybody know what the problem might be? because the really weird thing is, when i tried my oem bulbs that came with the car, the left and right both worked fine. please help me! thanks.
Old Mar 22, 2010 | 07:11 AM
CHISOX1's Avatar
If you've done the troubleshooting and found that all your parts work, I would bet that it's the connectors. I have 2 Tl's both with the fog HID conversion and at least once a year I have to take one of the front ends off and "jiggle" them if you will. The autozone by my house has these little packets at the registers of lube that you squirt on the connectors to give it a better connection and prevent corosion. It works for me. I'm not sure of the name.
Old Mar 28, 2010 | 11:51 AM
kp4lyfx's Avatar
do the foglight wires separate from one to two? is that why the fog wire on the passenger side has this "other" wire coming off of it and the driver's side doesn't? because i hooked up my hid kit and only the right side works so i'm thinking it's a problem with the voltage since the passenger side is using up all the energy so the other one's not lighting up. please help!
Old Apr 2, 2010 | 10:43 PM
kp4lyfx's Avatar
still didn't get this problem fixed. HELP GUYS!
Old Apr 3, 2010 | 12:05 AM
hANDYcaptd's Avatar
It's the Halladay season!
Have you tried switching the polarity of the connector going to the ballast?
Old Apr 4, 2010 | 07:39 PM
kp4lyfx's Avatar
i don't believe i can do that because it only fits one way?
Old Apr 9, 2010 | 06:03 AM
kp4lyfx's Avatar
gona take my front bumper off today. any ideas on what i should do to try and fix this problem? is the hid's i'm using for my fogs requiring too much voltage for both of them to light up?
quanaman
Jan 9, 2023 07:33 PM
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
thegipper
Sep 28, 2015 01:01 PM
