Engine Light On
Old 02-22-2017, 01:10 PM
7th Gear
antonico's Avatar
Engine Light On
The Engine signal came on as I was driving. The temp gage keeps rising as I drive, and drops as I stop. I pooped the hood - the radiator cap and hose are hot. Since the thermostat is new - less than 3 months old - is it a case that the light and gage would require only me to add coolant?
Old 02-22-2017, 01:12 PM
Received 8,712 Likes on 6,719 Posts
How's the coolant level? Radiator cap should be hot when you're driving. When was the last time you replaced it though? Any leaks? Either that or the fans are broken or the relays that control said fans.
Old 02-22-2017, 01:26 PM
What kind of thermostat did he put in? There's a proper orientation for it. Also did he burp the system, there may be air in it.
Old 02-22-2017, 01:29 PM
7th Gear
antonico's Avatar
Smile
Monday - I drove from my home in Van Nuys to LAX. The gage was doing the up/down moves as I drove, so I turned around and went to the mechanic who replaced the thermostat. I parked the car waiting for the fan to start - it didn't. I went in to talk with him for 3 minutes, we went to the lot back to the car. The fan had kicked on by then. We opened the hood - the hoses and cap were just warm to the touch after 50+ miles. Today, before going 2 miles the engine light came on, and after 10 miles of driving I got back, popped the hood, far hotter cap & hose. And this was just about 15 minutes ago. I suppose I could go down and check now to see if the fan came on to cool it down. No leaks - my parking space is clear. And I usually get the fluids topped as I change the oil - every 5k miles. Maybe someone forgot to add it? Not sure.
By the way I love your avatar. Although I'd love to know who's under Betty White's face !!
Old 02-22-2017, 01:30 PM
It'd also help if you read the code using an OBDII reader to see what the culprit may be
7th Gear
antonico's Avatar
I don't know. I could drive it back to him - but I just wanted to make sure the car was OK to drive it to him. The extreme heat to the touch had me worried.
Old 02-22-2017, 01:35 PM
7th Gear
antonico's Avatar
Thanks for the feedback . I appreciate it!!
Old 02-22-2017, 01:57 PM
no problemo
Old 02-22-2017, 02:20 PM
7th Gear
antonico's Avatar
Wink
no problemo
So who's under Betty White's face?
Old 02-22-2017, 02:21 PM
Wouldn't YOU like to know!!
Spoiler
Old 02-22-2017, 04:03 PM
7th Gear
antonico's Avatar
Spoiler
Hope he's grand !
Old 02-28-2017, 12:46 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
Ck driver side radiator fan operation at correct time, and does not run more than 1 minute after shutdown
Sounds like you have a rad fan sensor A problem (common) or water pump, or thermostat is NOT OE and upside down/rotated
Is the rad free flowing and clean? Why was thermostat replaced? type of failure?
IS the system burped per the book method with engine runs held at 2000 rpm till fan cycles then idle and cycles,
then 2000, then idle and final top off.
Old 02-28-2017, 09:38 AM
7th Gear
antonico's Avatar
It was a faulty relay. The sensor was telling the car it was too hot when it wasn't. Pep Boys had replaced the thermostat once, and as good as their word they took care of this with no charge.
vcam
11-18-2016 01:49 PM
NoTLoud
10-19-2016 07:53 AM
MussMan
10-18-2016 12:32 PM
zootjeff
10-15-2016 05:05 AM
YVRCLR
10-04-2016 10:05 PM
Quick Reply: Engine Light On
