AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   2G TL Problems & Fixes (https://acurazine.com/forums/2g-tl-problems-fixes-117/)
-   -   Electrical problems (https://acurazine.com/forums/2g-tl-problems-fixes-117/electrical-problems-973403/)
Shade Gaiven Sep 21, 2018 09:41 AM
Electrical problems
Need help.
lost use of my turn signals and tail lights. Fuses are good. Wiring looks good but I'm not a specialist in electrical. Alldata shows the two circuits seem unrelated. Have brake lights, reverse, and headlights. Not sure what is going on with turn signal and tail. Hope someone here can help.
thoiboi Sep 21, 2018 11:28 AM
front and rear? hows the cluster lights in the car itself.
Shade Gaiven Sep 21, 2018 11:31 AM
Front and rear. Everything in the cluster works except the turn signal indicators. Hazards are also non functioning if that matters. No hyper flash, nothing.
thoiboi Sep 21, 2018 11:34 AM
Did you install LEDs in the turn signals or something? There's a fuse in the driver's kick panel that handle the tail lights, did you test the fuse or just visual inspection?
Shade Gaiven Sep 21, 2018 12:08 PM
I have not. And visual check. But both system are unrelated according to the schematic
thoiboi Sep 21, 2018 12:59 PM
True but they both have fuses so that's the common denominator we're trying to rule out. Replace the fuses anyway to rule that out. Next would be checking the wire loom that runs along the the trunk lid. .
Shade Gaiven Sep 21, 2018 01:06 PM
Could a loom in the trunk affect the lights up front? Sorry, I know more about parts than I do electrical. Also, will have to rule that out for sure later. I may work in a garage now, but I cant pull in until after hours.
thoiboi Sep 21, 2018 01:15 PM
That's mostly for the tail lights. Also the root cause for both is the MICU/fuse panel in the driver's kick, hence why i wanted you to replace the fuses just in case.
With both being out, I can't see why it WOULD be an issue with the wire loom.
© 2026 MH Sub I, LLC dba Internet Brands
