EGR cleaning
Old 02-18-2006 | 03:05 PM
payluder's Avatar
EGR cleaning
Hello fellow acurazine I'm deciding to clean my egr but I did a search for diy and I cant find a walkthru about this can anyone help me. I ready did seaform, spark plug and some coil pack changes thanks to this forum.
Old 02-18-2006 | 10:18 PM
fsttyms1's Avatar
What year?
99.
http://www.in.honda.com/Rjanisis/pubs/SB/B00-004.PDF
00+
Here is the breif diy i did on it
this one still has a few pics left
Post #4
http://www.acurainspired.com/forums/...showtopic=4003
start off by getting 3 or so cans of SPRAY carb cleaner and acouple small scrub brushes.
if your engine is any thing like the 2nd gen
baisicly you take the plastic engine cover off 4 10-mm bolts. then disconect the battery. they disconect the rubber hose that goes from the air box to the throttle body. continue to unplg any thing that goes to the intake (any plugins hoses) then there are 10 10mm bolts on the top plate (the part that sticks up thru the plastic engine cover) oull that straight up being carefull to not damage teh gasket. then there are like 8 bolts (12mm i think, i cant remember off the top of my head) then you are able to pull the upper part of the intake manifold off (double check before you pull straight up that every thing is disconected) then get your self a nice place to work and start cleaning. (stick a bag over the TB before you hose every thing down like in my pic to be safe)
it sounds like alot but its really easy should take about a hr to do
Old 02-19-2006 | 05:30 AM
payluder's Avatar
Sorry I forgot to add I have a 2000 TL-P
Old 02-19-2006 | 08:38 AM
sbuswell's Avatar
I need 2 more gears
tip, when cleaning EGR port brake/parts cleaner works better than TB cleaner IMO. I used a plastic straw and wrapped a detail diaper(thin cloth material) around it and soaked it with brake/parts cleaner and worked it around the inside on the EGR port. Straw works great because it flexs so much and will not break apart easily. It worked great and EGR port was completely cleaned.
Old 02-19-2006 | 10:13 AM
fsttyms1's Avatar
they make nice little scrub brushes that work great. Plus old tooth brushes work great also!
hashbrown
02-18-2022 11:20 AM
08KBP_VA
10-22-2019 01:55 PM
fifer16
1G RL (1996-2004)
10-05-2015 10:12 AM
shawnafoxx
1G RL (1996-2004)
09-28-2015 12:33 PM
prbori
09-27-2015 01:37 AM
Quick Reply: EGR cleaning
