Door pins
Old Feb 14, 2010 | 02:14 PM
It's Clutch's Avatar
Hello Officer
Door pins
Well I have some problems with my dome light. I was told to check my door pins to see if they were alright. Noobie question, How do i check the pins?
Old Feb 14, 2010 | 02:26 PM
fsttyms1's Avatar
when you open the door the light should come on, when you close it, it should go off.
Old Feb 14, 2010 | 06:08 PM
MrChanh's Avatar
its the black rubber thing. if its nut bolted down then the light will not come on.
Old Feb 14, 2010 | 06:34 PM
friesm2000's Avatar
B A N N E D
first of all is the dome light switch in the "door" position, and not the "off" position
and does it come on in the "on" position
btw it sounds from the origional post, all the doors are having issues turning on the dome light
Old Feb 15, 2010 | 12:31 PM
Hello Officer
I knew that. The problem is that the light wont auto dim. The door pins are perfectly fine.
Old Feb 15, 2010 | 02:04 PM
friesm2000's Avatar
B A N N E D
auto dim like when you turn the ignition on, or after you lock it???
does it at least turn off, just not with the dimming effect
i can't remember if you have LEDs up in it, but the first thing i would do though is switch that back out to a normal bulb, and see if that fixes it, think of how the turn signal flash faster with LEDs, same basic idea, the computer is senseing something is different, and just shutting it off or so
Old Feb 15, 2010 | 02:40 PM
fsttyms1's Avatar
the auto dim isnt part of the door pins.
Old Feb 15, 2010 | 09:00 PM
mastini's Avatar
Like others asked: does it turning off at least?
after going with LED's - mine dimming only when i'm locking my car without key inside. (don't remember if it was dimming before or turing off right away)
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
soupi
14
Nov 15, 2015 11:15 AM
BIGxRED
Oct 19, 2015 10:47 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
