Dome lights not working.
![Angry](https://acurazine.com/forums/images/icons/icon8.gif)
So I realized today that not a single dome light works. I checked the bulbs which are good. The fuse was good except it was a 10A instead of a 7.5 which i dont think that it really mattered, but I put a 7.5A fuse in it. Still didnt work. Tried all the settings on the center light. Nothing. Now I really don't know what is up. I dont know if missed a relay if it even has one or if it might be a wiring issue.
Its a 99 TL. Any ideas?
Check the 40 amp fuse under the hood #54?
Check for power at the above 7.5 amp fuse?
Check for a open ground at the light?
You probably have no power for some reason, bc positions #1 (door activated) and 2 (manual on) at the center courtesy lamp uses two different grounding points.
mada51589
05-03-2022 08:54 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
