Dead OBDII port
Dead OBDII port
Hey all,
I have a 2002 TL-S that has had an intermittent SEL. The only other time the light came on was when the trans went out at 98k miles. To make matters more concerning, I replaced the cat a couple months ago with an aftermarket unit. I am guessing this is either another transmission failure or a cat efficiency code, but knowing for sure would be nice!
I went in to a local parts store to use their scanner and found the OBDII port to be dead. The TL is my wife's daily driver and I had met her there. I hooked up the scanner in my truck and it worked great. All fuses in both sides of the dash have been checked and are fine. I used my multimeter to check voltage between pins 4 and 16 and I get nothing.
Any ideas? Any input is greatly appreciated!
behind the shifter- that panel between/behind the seat heat switches
It comes off and the port is right there
Helps to move shifter to Low gear position to get your hand in and remove that cover
Yeah, I was going to drive across the street to a different parts store until I saw it work in another vehicle. It also made me more confident it wasn't the scanner when I had no voltage at the OBD plug. About the only thing I can figure might be wrong is a short somewhere in the wiring, but I was hoping there might be another possibility. I think I will double check with another scanner just in case something strange is going on!
Is the OBD port tied into the accessory fuse on these cars?
Thanks!
doh--I dont know every years specifics-had no idea they moved it and left the hole! thanks for the share!
SidhuSaaB
05-30-2020 12:40 AM
InFaMouSLink
10-30-2015 09:43 AM
