Click!
Old Sep 8, 2015 | 03:04 PM
Aging-Hacker's Avatar
4th Gear
Click!
I have fixed umpty-ump issues in my 2003 TL, just have one left.
If I accelerate briskly I hear a "click" from the passenger's front wheel area.
I thought the upper control arms were a bit loose, so I replaced those, no improvement.
All the other rubber parts look real solid. I did replace the passenger-side engine mount, it was failing, and that tightened up the throttle response, but the click is still there.
Any idea what could be clicking?
Old Sep 26, 2015 | 01:18 PM
Tosh's Avatar
Eurotrash
Not quite the same symptoms as you describe, but my front brake pads regularly rattle when going over bumps.
Old Oct 1, 2015 | 09:50 AM
01tl4tl's Avatar
odd to have a side motor mount fail on its own, normal is front goes-- then after some months of driving that way- the side mount fails
Clicking can be in the CV joint bearings
Have you listened with a mechanics stethoscope yet? Easy way to find noises!
Old Oct 5, 2015 | 11:44 AM
Chojun's Avatar
CV Joint failure is typically described as a 'click'.
Biggie_B
May 27, 2025 05:51 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Skirmich
Oct 1, 2015 12:59 PM
thegipper
Sep 28, 2015 01:01 PM
