check engine light. "Aux Emission Control" 2000 Acrua TL 3.2
Old Apr 17, 2009 | 02:23 PM
mike_s's Avatar
Getting Check engine light on my 2000 3.2 TL
plugged up a scanner (loaner from parts store) and it read
MANUFACTURER CONTOL AUX EMISSION CONTOL
I'm thinking this might be P1491, but their scanner wouldn't give numbers.
I cleared the code so I can see if it comes back again.
might be a EGR valve...
car is running ok, with no running rough etc..
any ideas or suggestions?
thanks Mike
Old Apr 17, 2009 | 02:50 PM
Gfaze's Avatar
S E L L
Sounds like a fuel vapor emissions system problem. You should check the lines to the fuel vapor canister and the related components for leaks.
Old Apr 17, 2009 | 03:03 PM
fsttyms1's Avatar
Might be the gas cap. Make sure you tightened the gas cap more than 3 clicks.
Old Apr 17, 2009 | 03:13 PM
Gfaze's Avatar
S E L L
That too, forgot about the gas cap being part of the vapor emission system.
Old Apr 17, 2009 | 05:31 PM
mike_s's Avatar
yeah.... I was wondering if it was the gas cap.
I went and tightened it and it was ok... but hard to tell sometimes with these that 'click'
I reset the code to see if it was a "one time thing" or will happen again. I've cranked it 3 times since the reset and no light yet.
I'll check the vapor lines as stated above.
thanks for these and any upcoming helpful ideas.
Billu99tl
Sep 13, 2015 11:30 AM
MikeYutkin
Sep 10, 2015 10:13 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
