Change PCV?
Change PCV?
Our TL 3.2 has 98k & change on it, and things are good—idle could be a touch smoother, but overall, we've kept it up well. But I'm wondering if I should, just for good measure, change out the PCV valve. It's inexpensive and seems easy enough to do. I welcome input. Gracias!
seafoam-gas and Master vac port
clean the TB air plate, spark plugs- NGK Iridium IX, air filter clean?
pull the intake manifold off and clean EGR passages and ports- that messes with idle and clogs up every 75kmiles
With that job, also do the IACV idle air control- inside the bottem of the TB unit
It gets clogged/sticky and causes idle probs-revving probs at idle etc
if the pcv part shakes ok- spray some cleaner thru it and reuse
thats not a big prob on TL , egr clog much more common
B A N N E D
you and seafoam again lol
but yes EGR clogging is more of an issue then the pcv on our cars
ok just for fries: bg44,seafoam, honda top end cleaner etc are all excellent ways to get the same basic end result = clean parts
Use of something is better than nothing
I was giving a few examples for different makers of quality product
You agree bg makes the right products- and their ad pops up all the time
at the mention of s-foam~
the honda T/E cleaner I saw-- was at their motorcycle shop!
lucas is a fuel additive that list itself as TE as well
Users want more info can use internet~
where do we draw the line on petty bickering fries??
mada51589
05-03-2022 08:54 PM
vpasla1
09-17-2016 07:24 PM
