Car shakes under accel @ 45-55mph - aligned/balanced/new ball joints
Hey guys,
I'm having a problem with my car: it shakes between 45-55mph.
Here's what I've done so far: I had the tires balanced. I also replaced the upper ball joint(camber kit) and lower ball joint on both sides of the car. I also replaced the side motor mount (the one on the passenger side). Then finally had it aligned since I wanted to adjust the camber.
I noticed that when i'm in that speed range, if i accelerate lightly, i will barely notice the shaking. However, the more my throttle is open, the HARDER it shakes. For example, I will be in 5th gear, and I lighty accelerate, I will beraly feel the car shake. As soon as I stomp the pedal, even if i'm not accelerating "hard", just the fact that my throttle is wide open makes the car shake like CRAZY. As soon as I let go of the gas, the vibration is gone.
I've also tried to pop it in neutral in that speed range and rev the engine, but it didnt shake at all, so it doesn't look like a bad front motor mount.
Have any of you had this issue before? I'm thinking of bringing in to the dealer and have them figure it out, but i'm scared it might cost me a fortune worth of "diagnostic".
Any help would be appreciated!
Hey I'm had the same problem after I had my car tires rotated within the last week. I took it to a tire shop and had them balance the tires within 0.00 to 0.15. They told me unless your going 175km/h you won't feel anything. Get your tires balance first to see it will solve your problem, its by far the cheapest method unless you can get the dealer to give you a free balance. They should since you bought the car there. Also when you balancing the tires had them check the suspension components in the front (i.e. upper/lower ball joints, bushings stabilizer links etc) to see if anything is a mist....
GOOD LUCK!!!!!!
GOOD LUCK!!!!!!
I had the same problem. Conventional (spin) or computer balancing did not resolve the problem. I had the tires road force balanced for about $60. That solved the problem. Google "Hunter road force" to find an independent that has this equipment.
Something is missing...my
also if you're only getting it under accerleration, then you may have engine stuff. I had an '00Accord V6 that did that. Then my buddy bought it and after 3 months one of his coils failed. So it may be that. Tires get flat spotted too. If this is the case the problem will diminish after driving for a bit.
So when you drive, do you relate it explicitly to speed or is it related to RPM's.
Resident Ford Tech
get them road-forced i see all the time at my dealership...new cars sit on the lot for months, tires get flat spotted, warrenty out the tires...its bullshit. You might also have a bad axle...
/etc/car
It's the half axle and CV joint. At this point, just take it to the dealership.
new symptoms!
NEW Symptoms!!!
It looks like when my car is cold, it barely shakes under the circumstances describe in my previous post. For the first 5min or so, it would barely shake.
Once the car is warmed up (ie 5min has past), the shaking would be back.
Could it be my wheel bearings? Or maybe transmission mounts? (not sure if the TL has tranny mounts though)
Anyone would like to share some ideas?
Thanks in advance!!
Thanks in advance!!
Cruiser
I'm clueless...there have been so many suggestions in reference to this problem that I have just chalked up as a defect in the build.... I haven't tried the cv joint suggestion though, but I tired of trying to figure this thing out.
SixSpeedDreamin'
Hey, one of your rims could be slightly bent. We just purchased a 2005 Acura TL and it was supposedly CERTIFIED. We couldn't see any visual defects at all and the car ran strong. Carfax the vehicle and everything. We made them put new tires on the vehicle and then we drove it home. My father and I wanted to OPEN her UP so we get on the highway. Between 50-60mph she was shakin' more than a stripper. Took it back to the Acura dealer and we found out that one of the rims were bent. Thats how we found out that the car wasn't CERTIFIED! Anyway they fired the technician that said the car was certified. That could be your problem, my friend.
dealer checked problem
So I brought my car to the dealer to have them check the CV Joints. They said they were fine and the shaking probably comes from the suspensions being too low (I'm on Teins SS). They also said motor mounts are fine and tires are balanced.
How do they explain my car not shaking when it's "cold" and only starts shaking when the car warms up? They said it happens!
Now i'm totally confused, i don't know what is wrong with my car anymore!
I'm thinking it might be because of the wheel bearings? could that cause the shaking?
Told Ya'LL...DYNASTY !!
yea mines being doing it forever, i replaced rotors, pads, all the engine mounts and tranny mounts, had the suspension checked out, and still have the shakes b/w 45 - 60, also dont have any problems for the first 5 minutes or so, so i just got used to it lol, i mean its probably not the right answer but at least itll save yourself some stress and aggrivation, im putting my rims back on shortly so i guess thatll answer the bent rim question, still got the stocks on it right now, too lazy and unable to find someone to fix my bent chrome foose's for a decent price, if anyone knows anyone on LI that fixes bent chromes with bends on only the inside of the rim that wont make me pay them for unnecessary rechroming please let me know lol
