Camber!!!!!!
is too sexy for his shirt
Camber!!!!!!
I got into a wreck a few weeks ago. i brought my car into school to do my alignment and my camber was way off... my teacher said there is no way to adjust camber on my car. is this possible? by the way i drive a 01 tl-p
If your camber is off you have something bent. There is no way to adjust it other than aftermarket stuff. I would suggest bringing it into a alignment shop or body shop to see whats bent.
was the acccident in the front or rear? i just had my car on the lift the other day and noticed my tire is down to the metal on the inside and when i inspected everything i found the knuckle was bent in towards the strut more than the other side was. i gotta get the knuckle now and then put it on the alignment rack to make sure nothing else is bent.
find out what they replaced at the body shop so you can narrow it down. it should just go right bak to them tho because when its done the car has to be perfect. when i worked at honda and we had body shop cars as soon as i put it on the alignment rack and saw camber was off i had to print it out and the body shop had to get more money from the insurance company to fix the issue. talk to the body shop first. they got paid to do a job and didnt complete it.
actually i haven't got the car fixed yet... only had liability and the guy that ran me off the road ran... so basically im kinda screwed. ill check what firestone tells me
No, thats not what im saying. I was saying nothing about lowering it. The question was asked if there was a way to adjust it because his teacher said you couldnt. Like i said if its off due to his "Accident" something is bent. Now if you are lowered or lower it it WILL effect your camber.
Always a Honda =Þ
to OP,
kinda funny(not that it happened, but your question), that you flipped your car and hit trees, and your issue is bad camber.
like everyone else said, have a shop look at it. im assuming, by your avatar, that youre not lowered. even if a camber kit can fix the bad camber, i would suggest getting whatever is bent, replaced. dont sweep the problem under the rug with a kit.
wasn't an extreme flip lol. i was going down a 2 lane road at about 50 and this guy in a small neighborhood on the right side ran the stop sign in his tundra and i was about 40 feet away. i slammed on my brakes and swerved into the ditch to miss him, car spun around went into the opposite ditch and flipped up onto its side
emailnatec
29
09-28-2018 04:27 PM
