Bad Wheel bearing? Left Rear making noise
So im guessing my have a bad rear wheel bearing, it makes a grinding howling noise at 20mph and more. its really annoying and it vibrates making the car feel un-smooth.
So im thinking about replacing the wheel bearing but WITH the Hub assembly from another wreck TL ? yay? nah?
and im pretty sure the hub just comes out right...?
For a wear item like a bearing, I wouldnt want to risk doing all the work and finding out your junkyard part is already dead/dies shortly after.
As far as how to do it Im pretty sure there is a DIY in here.
If its the rear, a new hub with bearing installed is actually pretty cheap.
The fronts require pulling the steering knuckle out which is a pain, then you have to press the bearing into the hub AND knuckle. But the rears are cheaper and a lot easier to do since there is no steering to deal with.
2012wagon
Sep 29, 2015 04:21 PM
