ahhh err 1....err 2.....
hey just recently disconnected the battery then when hooked up the battery i knew i had to have a cd player code....have the code, put it in, and err 1....tried again then err 2
any suggestions??????
greatly appreciated
greatly appreciated
tried the antenna connector didnt work....tried the main fuse under the hood didnt work....gonna try to disconnect the main fuse and antenna tomorrow hope it works.....if it doesnt any more suggestions???
tried taking out antenna connector and disconnected the main fuse for 10 secs put in code and err 8!!!!!!!!!!!!!!! started at err1 and now tried 8 times.....dunno wat the deal is...plz help
Good luck!
Bob
2G wanting 3G
the only thing that it could be is your putting in the wrong code. take your dash apart and get the s/n off the radio and call the dealer. unless its a 6disk, then you can just hold 1&6 and turn on the radio and it will tell you code. then call dealer.
Thanks got the s/n and will call dealer tomorrow hope they arent...well u know how dealerships are...o and this might be obvious but dont leave change between the heated seat buttons cuz I GOT JACKED like 5 bucks
Check out post #22 in the following thread:
https://acurazine.com/forums/2g-tl-problems-fixes-117/2003-3-2-tl-radio-codes-error-message-642967/
There's a link for retrieving radio codes online. I've never tried it but it might be worth a shot.
You can also try calling another local Acura dealer. Some dealers are more helpful than others.
