Acura 3.2 TL -PCM :- Please Help
I have to replace (Do it yourself) my PCM for 2002 3.2 TL ( no Navigation) .
can some one tell me how to remove exisiting PCM?
I know it is located under Center Dash console.
Are their two screws to be removed? I can easily remove the screw which I can see and accessible it after removing carpet from Passenger side.
How do I remove second screw?
Does second screw also easily accessible?
Do I have to remove center Dashboad console to remove second screw?
can some one tell me step by step how to remove exisiting PCM?
Appreciate your response.
have you looked in the DIY section?
Hello 01tl4tl,
Thank you for your response...i did see sticky for DIY ( see below) , but did not see it.
"Sticky: "New" Official 2nd Gen TL DIY Thread"
Will appreciate if you can guide me...thanks a lot!!
There isnt anything in the DIY thread on removal of the ecu. Its been a long time since i looked at the ECU but there is 1 bolt on the drivers side and i cant remember if its 1 or 2 on the passenger side. It will be easier to access if you remove the side panel. I think i removed the bolt on the passenger side from teh drivers side? I dont remember, that was years ago.
patilsd (07-29-2011)
BobbyGraham388
10-22-2015 05:05 PM
sockr1
10-01-2015 01:31 AM
Mike Bertram
09-10-2015 09:27 AM
asahrts
09-04-2015 05:55 PM
