AC/Heater blower works. Barely any air from vents. Any suggestions?
Old Feb 8, 2015 | 11:35 PM
rbrezzy's Avatar
poisonous darts
My blower motor recently stopped working a few days ago. Couldn't wait it out as it's been freezing here in this NY winter. So I went to my local autozone to purchase a blower motor. I installed it with some slight modification for wires and plastic/rubber hose connection from the original motor to the new autozone aftermarket motor. Got everything in place and connected. I then turn on the heat to full blast and the new motor kicked in like a champ but noticed that barely any air was coming from the vents. I rechecked my installation and didn't see anything loose. As I've stated before I did have to do some small modification to the rubber/plastic hose and got it to connect without crimping the hose. Turned it back on to full blast and still barely any air coming from vents. I'm now somewhat confused as to what the issue could be. Any suggestions out there as to what I could have possibly done wrong or forgot to do:confused?
Old Feb 9, 2015 | 11:07 AM
TLer trash's Avatar
It's probably spinning backwards. Try reversing the wire connections, even if the colors match up. I've been down this path before, and I think someone else on this forum ran into this recently.
Old Feb 9, 2015 | 09:59 PM
01tl4tl's Avatar
before you worked on it- there was correct vent operation?
often when blower stops its really the power connector failure- for it
That can destroy the resistor for the fan motor too
Old Feb 10, 2015 | 02:07 AM
rbrezzy's Avatar
poisonous darts
@TLer trash that scenario crossed my mind but didn't put to much though into it. But now that you mention it, that could very well be a possibility. I will switch the wiring and see the results.
Old Feb 10, 2015 | 02:12 AM
rbrezzy's Avatar
poisonous darts
@01tl4tl there was correct vent operation prior to new installation. I will try to switch the wiring around as TLer trash mentioned and post the results.
Old Feb 10, 2015 | 11:46 AM
01tl4tl's Avatar
Yeah trash has made his share of mistakes,,, and learned from them
Thanks for sharing experience and coming up with what seems like a fix!
swapped colors will get you every time
Old Feb 10, 2015 | 01:07 PM
TLer trash's Avatar
^^It's not the quickest or most cost effective way to learn, but you do tend to remember better. I also forgot that our blower motors don't come with with a pigtail. That style would be more likely than ours to be wired incorrectly.
Old Feb 10, 2015 | 04:58 PM
Guayaco90's Avatar
Hi. I have the same problem with a brand new aftermarket blower motor from Napa auto parts. It will work if I reverse the wires? Or I can damage the blower motor.... Let me know. Thanks a lot
Old Feb 10, 2015 | 06:52 PM
01tl4tl's Avatar
it will run backwards, just swap the wires
Old Feb 11, 2015 | 06:40 AM
rbrezzy's Avatar
poisonous darts
So yesterday i took TLer trash advice and switch the wiring around and what do you know, hot blowing air out of the vents. Simple fix and money saver.
@TLer trash thanks for the advice.
@Guayaco90 go ahead and simply switch the wires. I'm pretty sure if you are experiencing the same problem that very well might be the solution.
Old Feb 12, 2015 | 04:20 PM
Guayaco90's Avatar
it works !!!! thanks a lot guys.
Old Feb 13, 2015 | 04:21 PM
01tl4tl's Avatar
another ziners helping ziners success story!!
Every day I look for an opportunity to assist another human -or animal~
Old Jul 25, 2015 | 06:23 PM
bigjoe85's Avatar
8th Gear
This thread just saved me some serious $ I was just about to give up and found this thread. Thank you thank you thank you!
Old Jul 26, 2015 | 11:18 AM
01tl4tl's Avatar
glad you found us! there is info based on owners experience with this car on every subject
ck out our diy list, at top of thread list in the main area of forum
SidhuSaaB
May 30, 2020 12:40 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
stogie1020
Cameras & Photography
17
Sep 30, 2015 01:34 AM
dlknight
Sep 3, 2015 07:54 PM
