99 TL Rear Camber kit
Hi guys well I need help. My tires are inverted in from the top. And my car is lowered. OkaY I baught the adjusting bar one for each side. How do i go about installing them and is it hard. I read up a little bit. It says to pull in the bottom.
Hey Blaine209, you may have better luck checking the sub-forum : "Tires, Wheels & Suspension".
A much better resource for helping resolve your problem.
Install them and THEN get an alignment. You cant accurately get the wheels they way they are supposed to be.
As for installing them, Jack up the car, safely support the car on jack stands then you remove the stock bar and instal the adjustable ones in its place.
09-04-2015 08:03 AM
nuldabz
09-03-2015 05:49 PM
