99 TL Catalytic Converter R&R HELP!!!
Can somebody PLEASE point me in the right direction for a cat for our car in CA?!?!?!? My last one went out after 2 short years. Can I go aftermarket? How serious is the smog check with the laws out here? HELP PLZ REGISTRATION DUE and I don't know where to go.
I'd try a spark plug non-fouler on the back o2 sensor. I don't know how thorough california's visual inspection is, but you will probably have good tailpipe readings with the non-fouler installed. 2 years out of an aftermarket convertor isn't all that bad. Some of them will set a cel right out of the box. Check around; you may have an extended warranty on your convertor.
Ya if you have $1,000,000 laying around :|
2000 Acura TL
FWIW, I change an aftermarket CAT on my Odyssey van and it passed smog, but then six months later code came back, so then went with non-fouler route and no code since, but have yet been back for smog with non-fouler.
Registered Nonmember
As far as I know it is illegal to install any aftermarket cat on a vehicle equiped with OBDII (post 1995 i think) in cali. However with aftermarket cats at $200, high-flow cats at $300, and the stock cat at $1500, most would probably try an aftermarket solution and hope they don't get too nosy during the visual inspection.
I agree with quinn; the last I read, there was no aftermarket cat legal in california. I think that is recent because you could go aftermarket previously. I think the minimum, federally mandated warranty every cat mfgr. must offer is 24 months, so get yours warrantied.
But as far as aftermarket reliability, what are our options...Xlr8 hfc? Any others?
They will all work reliably with regard to engine performance. As far as setting a p0420 code most of the aftermarket cats will only reliably keep the cel off if a spark plug non-fouler is added. Sometimes they will be ok for a few months up to a couple years, as the emaka9 has experienced. The factory cats cost 3 or 4 times what an aftermarket sells for, but will usually go as long as the original before setting a cel. With the xlr8 cat you get increased performance and a little louder sound as a bonus.
victus1 (03-07-2013)
haha uhhh?
Just bumping to see what you ended up doing emaka9.
I just went though smog with my stock cat and now am thinking about headers and high flow cat for the next two years. I watched the inspection--he never looked under the vehicle. With the shroud over an aftermarket cat i think i could pass visual. I'd also have two years to figure out a good solution to obscure the headers. hmm...
I would like to have the XLR8 one, but not with stock exhaust. I want to do headers, xlr8 cat, and exhaust, all at once. But that's way too much right now. So for now, I'm using this pos cat...
TheMightyQuinn (06-11-2013)
