Help me find a used replacement part. It is number 6 on this picture. I don't need a brand new one.
MOTOR ASSY., AIR MIX for 1999 Acura TL|79160-S0K-A01
thoiboi
close
- Join DateApr 2010
- LocationSoCal, CA
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:9,170 Times in 7,045 Posts
Post belongs in Black Market not here
Never mind. I went to my local salvage yard and was able to get a couple of them for dirt cheap.
justnspace
close
- Join DateFeb 2010
iTrader Positive Feedback100
iTrader Feedback Score(1)
Liked:16,291 Times in 11,991 Posts
Quote:
fuck, i need one. and I bought one from a junk yard only to find out its broken exactly like mine....Originally Posted by Black Tire
i tried ordering new from acura for 140, was fine with the price.....but only to find out Acura has none! and are currenlty on back order
Open it up and rotate the big gear 180 degrees so the bad teeth are no longer in use. WFM. Cost $0.00.
[the gear only rotates about 90 degrees over the course of its travel to move the blend door.]
Worked perfect for me as well, I was thinking about opening it up to see what was making it hang up and came across you post. Many thanks! Originally Posted by smcafee
Open it up and rotate the big gear 180 degrees so the bad teeth are no longer in use. WFM. Cost $0.00.[the gear only rotates about 90 degrees over the course of its travel to move the blend door.]
Was super simple, hardest part was getting the assembly back in the car.
