3rd and 4th gear switches location on 2nd Gen
Old Apr 18, 2011 | 02:28 PM
hjvel's Avatar
7th Gear
Where are the switches located on a 2nd Gen TL?
Specifically a 2000 TL.
Thanks.
Old Apr 18, 2011 | 05:46 PM
tc5280's Avatar
Flagship Aspec
take off the driver front wheel and you will see the cover towards the front of the well.
Old Apr 20, 2011 | 11:33 PM
hjvel's Avatar
7th Gear
Thanks tc5280!
There they were.
Old Apr 21, 2011 | 01:57 AM
01tl4tl's Avatar
cleaned-replaced--results?
Old Apr 21, 2011 | 02:34 PM
freebieman's Avatar
are they in the same place on the 1999 tl? also, i looked on acuraoemparts.com but couldn't find pressure switches... is there another name for them?
Old Apr 22, 2011 | 10:00 AM
01tl4tl's Avatar
selenoid
Old Apr 22, 2011 | 11:36 AM
clue036's Avatar
Parts #12 and #13 are the pressure switches that usually need to be changed out? Or two of #14?
Old Sep 27, 2012 | 02:30 PM
onedollabills's Avatar
help needed
Hate to resurrect this thread, but I can't find an answer any where. Is the 4th gear pressure switch on an '03 TL also called driverside upper or lower switch? When trying to order the part I only come across "upper" and "lower" switches.
Old Sep 27, 2012 | 03:45 PM
01tl4tl's Avatar
ck the DIY section for help and parts numbers including the external filter
third item down main gen2 threads OFFICIAL DIY LIST
Old Sep 27, 2012 | 11:20 PM
closetprisoner's Avatar
2000 Acura TL
here you go.. pix and location of my diy
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
NitroViper
Mar 20, 2017 09:50 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
Sep 17, 2015 10:09 AM
Skirmich
Sep 15, 2015 06:41 PM
