2003 CL no high Beam
No power or ground to the 9005 bulb. Just bought this car used. Bulb was blown. Changed it but not working due to no power and ground. Anyone have a schematic?
thanks for the input. Bought Mitchell on demand for a month. Downloaded schematics I needed. Original problem. No high beam RH. But I also did not have DRL. Looked at the DRL module as that’s where the RH high beam light gets it’s power from the DRL. Pulled the module apart. Didn’t look great. Wrecker beside work had the same model. Pulled the DRL module. Looked perfect. Plugged it in. All good now.
whitetiger5 (10-24-2023)
Welcome to Acurazine @Gdub64 , you posted a CL issue in the TL forum, so it may not get much feedback.
What's Mitchell on demand? There are pages here where you can find links to both the TL service manual (many links) and the CL service manual (a few links).
Also, I don't think many on here have DRL's, your support on that particular topic will probably be sparse, but many other (especially mechanical) issues will be well supported.
For both topics above, google is your friend. Start searches off with "Site:acurazine.com" and enter your keywords.
Thanks for the reply.
My bad putting CL in TL.
Mitchell On Demand DIY. Googles your friend. Comes up as eautorepairs.net.
I could not find any links to schematics that didn’t ask for your credit card. Not doing that to a random sight I am unfamiliar with. Above used PayPal.
You are right about DRL. Kind of a Canada thing.
Google got me down the rabbit hole of the Internet. Circled back to Acurazine a few times. Which got me back to where I was earlier.
Anyways. Got it all done. Works good. Info there if someone else experiences this.
Just to add to it, I did find that there was circuit board information of the DRL cracking the tracks. Kind of looked like mine was doing that. Re-solder is said to fix it. My used one was in perfect condition for $35.
kostakong
01-11-2017 06:54 PM
