Glovebox Rattle
Old 08-21-2010, 09:52 AM
Received 5,293 Likes on 3,627 Posts
Glovebox Rattle
Discovered a new noise recently.
Only in turns, sounds like something sliding/rolling across the glovebox. Nothing in it except the owner's manual.
Old 08-21-2010, 10:40 AM
It's the Halladay season!
hANDYcaptd's Avatar
More detail? Does it happen in all turns? Or only fast, or only slow. Does it make noise when you turn the wheel at a standstill?
Old 08-21-2010, 11:03 AM
Pretty much all turns. Haven't tried just turning the wheel sitting still. Sounds like something inside the dash in the glovebox area is loose and sliding around.
Old 08-21-2010, 12:33 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
must be time to change the cabin air filter-
glovebox is removed as part of that diy so anything in or behind it should be found
Old 08-21-2010, 12:35 PM
First car I've had with a cabin filter....forgot about that. I'll have to look into it.
Old 08-21-2010, 10:24 PM
totaledTL's Avatar
Maybe something fell down in the plenum and is causing the noise. If you've had the car a while & never replaced the filters get ready, they're probably nasty.
Old 08-22-2010, 04:21 PM
Had my wife in the car with me today, she said when the reattle happened, she felt the noise in her feet. So, maybe something under the passenger floor? Is there a "pocket" under the floor pan? Where something could be moving around?
Old 08-22-2010, 08:06 PM
01tl4tl's Avatar
ck under seat for missing golf balls?
who are you going to believe--us on the other end of a modem,
or your spouse the diagnostic expert?
Old 08-22-2010, 08:07 PM
01tl4tl's Avatar
at her feet would be the cabin air filter-
you cant believe what gets in there!!
marcelft
07-10-2018 06:17 PM
udelslayer
1G RDX Problems & Fixes
05-06-2016 12:27 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
jaynatlanta
5G TLX Problems & Fixes
09-15-2015 11:08 AM
3GTLOwns
09-09-2015 09:51 PM
Quick Reply: Glovebox Rattle
