2003 Acura TL 3.2 Transmission Issue
3rd Gear
While driving my 2003 Acura TL 3.2 (288,418 miles) the vehicle holds at 20 mph at 2,000r/min. Roughly 20-30 seconds later the car begins to increase speed gradually at the same 2,000r/min. My mechanic completed a ATF change to OEM ATF directly from the Acura dealership. This issue still seems to occur, any possible suggestions as to what the problem may be and what can be done to correct the issue?
Note:
* Issue occurs while driving in D4 and D5
* Vehicle shudders when placed in reverse and D5
* Check engine light on that reads a O2 sensor code.
* spark plugs last changed roughly 1 year ago.
Note:
Note:
Note:
3rd Gear
3rd Gear
Agree. I put in a '07 V6 Accord in my '03 TL Type S almost 100k miles ago and it's still going strong. Cost me about $1,700 between the cost of the transmission and installation.
my '99 transmission failed at 99,000 miles and Acura replaced (after they extended warranty to 100k. That one lasted another 85k and it died. Replaced with an 07 and it currently has 267,000 on the original transmissions. As others have mentioned above, the Accord transmission replacement (if you can find one) seems to be a good alternative.
Good luck.
Good luck.
99 had a 4 speed and then changed to 5 speed
frankjnjr (06-24-2018)
Joy4
07-23-2018 12:15 PM
