1999 TL nav & radio code
Just had my transmission go out and replaced and now my navigation and radio are asking for pin number codes. I bought this car used and in such do not have the card that is supposed have those codes. Is there any way to get my systems back up and running without having to take it to a dealer and pay for them to take out the systems and replace the codes? Need some help if this is possible
Missing Machismo
some are posted on the back of the radio itself.. thats only some not all...
p.s. if you had your transmission replaced by an authorized acura dealer.. they are required to give your car back the way they recieved it minus new transmission... this includes resetting the radio. this is common problem for dealerships to handle just call them and tell them.
the radio code is on a sticker somewhere on the car, most are found in the trunk on one of the hinges that flip the lid up. If its not there look in door jams and around the engine compartment. The radio code will be a 5 digit number. Also if you bought it used from the acura dealer then they might have your code on file, give them a call and see.
I Have A 00 Tl And The Serial That The Dealer Its Asking For, Its In The Right Wood Panel The Goes Down Your Console There Should Be A Sticker Behind Call The Dealer Give Them That Serial And Should Give You The Code Some Service Guys Are Assh...... But Try Diferrent Dealers Goo Luck Let Me Know
