[b]possible power steering leak help![/b]
I have a 00 TL. I've noticed that my power steering level has been going down pretty quickly. So I decided to check it out. The power steering still work but I found a badly corroded line running from the reservoir that I believe is causing the problem. Is there a quick fix for it or does the whole system have to be removed ?
You only need to replace the bad section. The lines, or pipes, as acura calls them are available in sections at the dealership. If that looks too daunting, you can splice in 3/8" trans cooler hose, as it's on the low pressure side. Judging by the amount of rust, you might want to let a professional do it.
mike from annapolis
05-07-2017 08:21 PM
