Nuespeed strut bar...(DIY maybe?)
Drivin' it till it dies!!
O.k. guys. I did this a while back but I read somewhere that some members actually had to drill out their strut bar holes (oval shaped) in order to bolt it up. I didn't have to. This may be useless information to some, but I figured I'd share anyway. Here's how:
First un-bolt two nuts on passenger side:
![](http://i57.photobucket.com/albums/g213/pistacio103179/HPIM0596resize.jpg)
Un-bolt all five driver side nuts, then carefully jack-up your car on this side only and push down on your driver's side wheel until studs receed into wheel well leaving only a few threads showing. The reason for this is that it will allow the strut bar mounting holes to align correctly with strut tower holes, thus, not needing to drill the strut bar holes bigger:
![](http://i57.photobucket.com/albums/g213/pistacio103179/HPIM0603resize.jpg)
Insert strut bar into two passenger side studs:
![](http://i57.photobucket.com/albums/g213/pistacio103179/HPIM0608resize.jpg)
And now the tricky part, While pushing down on the driver's wheel again, push until the strut bar is making contact with the strut tower, and slowly release pressure from the wheel until the studs start to go through the strut bar holes. The reason why this is tricky is because the studs will want to hit the outside walls of the strut bar mounting holes. Just tap the strut bar slightly and the studs should pop thru.----This is where other members just drilled out the strut bar holes in order for the studs to go through. To me, that just defeats the purpose of having it because it supposed to be a tight fit in order to tie the strut towers together reducing chassis flex.
![](http://i57.photobucket.com/albums/g213/pistacio103179/HPIM0604resize.jpg)
Now, thread all the nuts on to be sure nothing pops out of place, and let the car down off of the jack SLOWLY. Once the car is on the ground, tighten all removed nuts.
![](http://i57.photobucket.com/albums/g213/pistacio103179/HPIM0617resize.jpg)
![](http://i57.photobucket.com/albums/g213/pistacio103179/HPIM0610resize.jpg)
I explained this the best way I knew how to. If anyone has anything to add or re-word, feel free!!
I Bought The Strut Bar Used. It Was Black And All Chipped Up, So I Painted It Red. I Like The Way The Red Contrasts With The Blue.
Jacking Up In The Middle Works Too! I Just Didn't Want To Go Through The Trouble (limited Space In The Garage).
Lamborghini Aventador FTW
Nice job, I installed mine on Saturday. One question though, I tightened all the nuts while the car was still jacked up (from the middle). Should I have tightened them once the car was on the ground? It seemed as though I should tighten the bar while it was jacked up because otherwise it wouldn't contact the car flush.
FPR pimpin'
nice, i woulda prolly painted it blue.. but it matches the red letters so it looks good still nice i thought u would just unbolt the two bolts that the bar uses and thats it.. good diy will come in handy
Your O.k.. I Think Either Way Would Work As Long As The Upper Strut Mounts Make Full Contact On The Under Side Of The Strut Tower . I Guess If You Tighten While Its On The Ground, The Upper Strut Mounts Will Make Full Contact With The Under Side Of The Strut Towers Because The Weight Of The Car Is On Them.
Originally Posted by L3wD
nice, i woulda prolly painted it blue.. but it matches the red letters so it looks good still nice i thought u would just unbolt the two bolts that the bar uses and thats it.. good diy will come in handy ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
I DIDN'T WANT TO GO BLUE BECAUSE, TO ME, ANYTHING ELSE PAINTED BLUE WOULD BE OVERKILL ON A COLOR LIKE ABP.
That's Why I Went With The Neuspeed Bar Because I Think Its The Only One That Fits Without Removing The Factory Brace. I Bought A Cheesy One For A 98-02 Accord And It Interfered With The Stock Brace.....it Was Only $30.
Originally Posted by AMGala
I didn't have to, in fact my car now has more centering feel than it did without the extra strut bar
02type-s ...thanx for the comment
lanechanger
10-13-2015 10:56 AM
