MY TL 10lb BOOST
Old 09-13-2007 | 10:48 AM
  #41
myTaLizaS3.2's Avatar
you are a very bold man dirty
Old 09-13-2007 | 11:15 AM
  #42
datzdaboi's Avatar
B A N N E D
The newer pics are nice.....but I think you shouldve put a type s motor and 6 speed with boost and juice
Old 09-13-2007 | 11:41 AM
  #43
just taking a wild guess, this setup should be somewhere around 2 to 3k to do huh dirtyjohn?
Old 09-13-2007 | 12:36 PM
  #44
DIRTYJOHN's Avatar
i only spent 700 so far..
i did everything myself thats why
  #45
DIRTYJOHN's Avatar
i already have all the injectors and a E management laying around,,
  #46
DIRTYJOHN's Avatar
  #47
DIRTYJOHN's Avatar
Old 09-13-2007 | 12:51 PM
  #48
lostkhan's Avatar
Now what i wanna c is the Dyno Chart w/o the Juice and also a 1/4 With and without the Juice.
Old 09-13-2007 | 12:58 PM
  #49
BraveDemon's Avatar
I'm Down Right Fierce!
Hmm...
Now the question is, how will the tranny hold up underneath the pressure of 10lbs of boost and spray?
I agree with TLSu, the CL-S 6 speed tranny will probably be a good investment.
Old 09-13-2007 | 01:12 PM
  #50
Autoworks's Avatar
Is that your downpipe facing down right here?
Old 09-13-2007 | 02:24 PM
  #51
DIRTYJOHN's Avatar
yes sir.. THREE INCH
Old 09-13-2007 | 02:34 PM
  #52
`ill*tl's Avatar
Originally Posted by BraveDemon
Hmm...
.. if I'm not mistaken, DIRTYJOHN has rebuilt his tranny and it seems to be holding up just fine from the vids I have seen.. especially the one where he sprays in 1st.
Old 09-13-2007 | 02:45 PM
  #53
blk2001tlon19s's Avatar
318whp/289wtq @ 6psi
I would suggest swapping turbos now. Your turbo appears(could be wrong) to be a t3/t4 which is really a little more for a 3.2 v6. You can get by using the emanage blue also opposed to the ultimate and some some money. You could also pick up some used s2k injectors which are 370cc instead of picking up 550cc injectors depending on what you are looking for. Your fmic should be fine. A bigger fmic doesn't make it better. The better the , the better the FMC. Good luck.
Old 09-13-2007 | 02:47 PM
  #54
Originally Posted by JOES05tl
dirtyjohn is real as fuc. Maybe the pic is fuct, but hes working on some shit in it, right? just cuz' he didnt respond right away, the posts will progressively get worse- happens to me everytime. HAAA-
What are you talking about? I don't think anyone said he was lying, etc...people are just asking questions, this is a forum I believe and asking questions is normal if I remember correctly..
Old 09-13-2007 | 02:53 PM
  #55
@cUr@-TL's Avatar
'99 Acura 3.2TL
im not a turbo expert but i wouldnt trust that shit from ebay. why put cheap stuff on a TL? this is not a d15 civic.
Old 09-13-2007 | 03:42 PM
  #56
hAadOokEn's Avatar
we'll all see if he got his moneys worth or not i'd say its a good investment since he has his own shop and all. and we can all learn from him to
Old 09-13-2007 | 03:43 PM
  #57
Hockeyman's Avatar
slobalt defender
where you at in texas man i wanna come check that shit out!
Old 09-13-2007 | 04:22 PM
  #58
Autoworks's Avatar
I'm guessing you are going to keep it open. By the time you add a mandrel 3" bend to it to face it to the rear of the car it appears that it would literally only be 1-2" off the ground...suspension travel and bumps will kill it.
blk2001tlon19s- That is definately an ebay turbo. The sizing and trim of the T3/T4 would be the big factors. The "T3/T4" in general is pretty broad. I use a T4/T4 on pretty much everything, just in several differet trims and A/Rs. I too would like to know the trim and A/R on the turbo.
Old 09-13-2007 | 06:35 PM
  #59
nguyen's Avatar
i think hes from houston
think i saw him at tan tan one time..
Old 09-13-2007 | 07:14 PM
  #60
DIRTYJOHN's Avatar
i am in houston texas/
122 east rose lane
houston tx 77076
i am always at my shop.. I will post up vid ASAP.. will show u everythinggg.. OOO those of u who wants to turbo your car!!! u need this spacer thingy for your map sensor or else it wont boost. I just lowered the boost down to 5lb due to My Emangement problem :/ DONT WORRY GUYS EVERYTHING WILL BE IN THE VID As SOON AS I POST IT UP.. DUDE IT RUNS REALLY REALLY REALLY GOOD
Old 09-13-2007 | 07:15 PM
  #61
DIRTYJOHN's Avatar
yes its a EBAY TURBOO!!! it works really good
Old 09-13-2007 | 08:31 PM
  #62
Autoworks's Avatar
Are you referring to a map checkvalve? You shouldn't need one when using the E-manage.
Old 09-13-2007 | 10:48 PM
  #63
DIRTYJOHN's Avatar
look up!! i say i just dropped it down to 5lb of boost because my emanagement isnt working right now :/ so i have to pull out my safc (not vafc).. sigh.. But will have it back in a week and i swear that 10 lb is coming.. If anybody wants a ride in the TL feel free to come by I should suggest all second gen TL owners get TURBO. If u want one PM me and i will build the piping for u. O if u order the kit on EBAY trust me its worth it for its money just bid on it and u will pay a total of 425 and will get to u in three days.. If u get it PM me and i will help u get your turbo ON.
Old 09-14-2007 | 06:52 AM
  #64
Autoworks's Avatar
All the check valve does is bleed boost before the map sensor picks up on it. Whether its 10psi or 2psi, the sensor will react the same to it. You should still come to the same problem as soon as it crosses over from vac. to boost.
Are you able to make the car run in boost without a CEL right now?
Old 09-14-2007 | 10:37 AM
  #65
CL-S6's Avatar
Turbo 6 Speed
Are you useing the Accord V6 / Acura V6 Turbo Kit / 3.0L V6 Single TURBO kit off ebay?
Old 09-14-2007 | 11:24 AM
  #66
DIRTYJOHN's Avatar
yess. BUT i have to rebuild everything.. THAT SHIT DONT WORK... i have a muffler shop so its pretty easy for me.. but if u buy that kit i will guarantee u that shit wont fit.. nothing bolts on right except for the headers
Old 09-14-2007 | 11:25 AM
  #67
DIRTYJOHN's Avatar
YEAH its boosting right now NO CEL
with the check valve. it raise the map sensor by 1 inch and only send the map a 1lb max thats why it works.. BUT dont be foo.. IF anybody running turbo make sure u have some kind of emanagement or else your motor will detonate..
Old 09-14-2007 | 01:02 PM
  #68
CL-S6's Avatar
Turbo 6 Speed
How much power do you think its making on 5lb of boost?
Old 09-14-2007 | 01:34 PM
  #69
02TLSfan's Avatar
Prick of the month
122 east rose lane
houston tx 77076
Hey Dirty, I'm going to be in Houston this Saturday(tomorrow) for the Killers concert, if you're going to be around I would love to check this out. My girlfriend is gonna kill me, but I gotta see this and take a ride!
Old 09-14-2007 | 02:20 PM
  #70
DIRTYJOHN's Avatar
thats cool give me a call 7136240437 ill be at my shop
this is the vid of the motor running with turbo
http://youtube.com/watch?v=aNwATZy2PLk
this is the vid me running a wrx
http://youtube.com/watch?v=ecLWquXBnhE
Old 09-14-2007 | 03:37 PM
  #71
Autoworks's Avatar
Actually that's not true. A check valve just doesn't let the map pickup on boost...whether it's 1" or 3" it would serve the same purpose.
I see you are running a FMU and checkvalve, which is basically old school fuel management...drag still uses it to this day...but it needs stock injectors to even run 1/2 way correct with the FMU.
(I'm sure all my post make it look I'm being a dick, but I'm not. I'm just pointing out things that are obvious to me but may come across as misleading or incorrect to others that don't deal with FI setups on a regular basis)
Old 09-14-2007 | 04:37 PM
  #72
mrchan625's Avatar
u sick bastard....
Old 09-14-2007 | 06:24 PM
  #73
S1CK TypeS's Avatar
B A N N E D
dirty clear out ur PM box
Old 09-14-2007 | 06:36 PM
  #74
MegaKillTron's Avatar
The wood god
Damnet John, why couldn't you do this when I was still living in Houston?! I"ll come by the shpo and check it out when I visit in December.
Old 09-14-2007 | 06:48 PM
  #75
DIRTYJOHN's Avatar
(autow0rks) I totally understand your point.. you make very good point. in order for my car to run i have to put what i put.. I was gonna ask u if you are around houston u can come check out my setup and help me out with some stuff.. I know u know alot about cars cause everything u say so far makes perfect sense..
  #76
DIRTYJOHN's Avatar
Mega Kill U Need To Come By My Shop When U Get Into Town Foo
Old 09-14-2007 | 09:15 PM
  #77
mrnewguy's Avatar
B A N N E D
wow i hate you john. is ur car a sleeper? lol what am i saying, like a boosted TL isnt sleeper enough. i mean like no lip kit stock height and shit?
Old 09-15-2007 | 04:50 AM
  #78
'03TL-S's Avatar
he has a lip kit, but with the 99-01 front lip
Old 09-16-2007 | 03:21 PM
  #79
00 acura tl's Avatar
Inspired
will an accord turbo kit fit a 00 tl?
Old 09-16-2007 | 03:30 PM
  #80
6MTUA5's Avatar
No He Can't
Probably not
Quick Reply: MY TL 10lb BOOST
