would subwoffer work in stock radio 2000tl?
I need 2 more gears
there are no pre-outs on stock HU, but you can run an adapter from HU w/o by-passing the EQ I believe. I have stock HU and am running 2 12's now for over a year and no problems. The adapter was like 20-30.00 but install is a bitch, you have to remove entire center consol and the dash to get to the back on the HU. Make sure you know your HU code or you won't be able to turn the HU back on.
are you kidding? behind the seat? if that is true what a waste of time(my way)!
Missing my Acura's
Originally Posted by fsttyms1
Nope not kidding. Thats where the amp is for the sub. and the leads run right to it. Or you can get a line higher capacity line converter and hook it up to the high side (the leads that conect to the sub) in the trunk!
Registered User
Originally Posted by FiftyFive
ok so im thinking of hooking up my system to the factory headunit what do i need exactly and what do i have to do
i have an amp and 2 subs
you will need to run a power wire from the battery to the trunk. You will need to get a good ground in the trunk. You will need a line converter to hook up to the sub leads by the oem amp (behind rear seat) rca's to go from converter to new amp, and a remote turn on wire, either run from drivers side fuse panel or tap into it at teh oem amp
Yeah, You can hook up an amp & sub with a stock HU. But your amp would have to have a Hi Output port. Its a special plug in type thing. It has 4 wires. All you do is tap into the middle sub, 2 + and 2 -.... This replaces RCAs. And the REM, you jus run the wire to the GROUND part of the amp.
Thats all it is.. Hope it was helpful...
IMPORTANT:: When you shut off the car YOU MUST DISSCONNECT the REM wire from the GROUND..
Or else you might blow your SUBS.
handsom-hustla
11-13-2015 05:04 PM
Luis J. Rodriguez
09-12-2015 10:00 PM
