type-s gauges
you can buy the assemblies for around 30 bucks each new and plug them into your existing cluster and things will work just fine. You will have a issue with the (i believe its the VSA/TCS light due to location but every thing else will work just fine. Redline will be higher so you will have to learn where it actually is on the new cluster
Yes they will be correct for the 00+. 99s will need some custom work to get the gas gage to work properly (there is a thread on how to do it but search isnt working right now to find it). The only real difference is the Type-s has a higher redline. You wont be able to utilize it as your motor wont rev that high and you will have to remember that if and when you use SS
http://www.acuraautomotiveparts.org/...catdisplay.jsp
Your Garage
http://www.andysautosport.com/acura/...a00124360.html
Received 1,080 Likes
i guess.. id just get the reverse glow and not have to worry about the different redline and indicator lights since hes trying to do it on a 99
And buying anything from www.andysautosport.com is just asking for trouble.
Buy the face plates and stick them on. You will have to recalibrate every thing but every thing will work
I find the reverse glow gauges to be extremely ghetto.
I have a 2000 TL-p that I replaced with the stock gauges. I put my stock board in the TLS gauges so I could have my original mileage. Everything fit perfectly. TCS light does not come on when TCS is disengaged. Other then that so far everything seems to light up properly. I got the TL-s gauge cluster on ebay for I think 100 bucks shipped.
IMO it looks A LOT better then the stock TL gauges.
so fasttyms1 you think i should just buy the silver faces and change them out instead of buying the whole cluster? and i can use the silver needles to right
tl-s
heres a set of tl-s gauges cheap http://cgi.ebay.com/ebaymotors/ws/eB...m=280261354841
I have 02-03 Type-S gauges on my 99-TL-P.
Thing to Know when changing 99 to 02-03 gauges
When started your car, you when notice is that your Temperature needle is on "H" an stay there. The 99 has TCS an 02-03 has VSA, This problem only cause the VSA light stay "ON" (no big deal) You have D4 in 99 an 00+ up have D5. Your miles will not be the same. You can play catch with your new gauges Good thing it a plug an play. I change mine out B/c i like Sliver look then black face.
DerrickW
11-15-2015 05:52 PM
