SS lines with Legend Calipers?
She thinks my TL's sexy.
I already have a set of the Goodridge stainless steel lines and I have decided (due to a stuck bleeder) to do the Legend caliper upgrade. Does anybody know if these same TL lines will be a correct fit for the Legend calipers or if another part is recommended?
I need 2 more gears
Sounds like you either didn't tighten it correctly or cross threaded it. Goodridge makes very good SS lines. I ave Racing Brakes SS lines and love them, but don't see them as being much better than Goodridge.
Anyway, I installed the 2 piston Legend calipers, and I have to say that I noticed a big difference. Not sure if it's phsycological or not...but it feels like the car stops that much harder/faster. Next up are the ss lines and I'm pretty much done with brakes. I may get some rear rotors but not sure if those are really necessary since the fronts get the brunt of the work.
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
It was prob the washers that where leaking..
When I put on my NSX calipers the old washers leaked, put the new washers on problem solved..
I still get a metal rubbing noise from my NSX caliper I havent had time to take it off and check it out but I think it is the metal plate that sits on top of the caliper inside hitting the rotor..Do the Legend calipers have a metal plate on top of the inside of the caliper?
B A N N E D
what r those metal plates suppose to exactly do?
If I remove it will there be a problem?
That cis cis cis noise is really getting to me i know my caliper is not locked up changed my brake hose and pads are not stuck just keeps making that cis cis cis noise and im thinking its that metal bracket think !
As far as what they are ther for
Remove them and
B A N N E D
When I first installed my legend calipers, I left them in and they rubbed the outside of the rotors and made an awful sound. When I removed them, the sound went away and all is good. If you have them (metal brackets/plates at the top of the caliper) on, this is most likely the source of your woes.
Remove them and
Remove them and
Thats what i was thinking, I checked everything , took them off and reinstalled everything twice and still making a metal rubbing noise cis cis cis..
I was thinking that was it just had not had time to take them off yet. I will do it when I install me back pads and rotors in the next few weeks.
It is funny though cuz its only the passenger side not the driver side.
Your driver side retainer may be bent away from the edge of the rotor just enough to prevent it from rubbing, and thus no sound.
While you are there, it would be prudent to check out the splash guard as well to make sure it did not somehow bend and come in contact with the rotor.
If the retainer or splash guard are not the source of the noise, there is not much else coming in contact with the rotor other then the pads.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
