seat up grade
seat up grade
was wondering if i decided to upgrade my 99 seats to 02-03 tls seats will i have to convert the harness and door panel too as will as harness for the side air bags, or will it just plug n play? has any one done this? just like the bucket seats and the side air bag
yes you will have to switch out the haness, or just figure out how to make it work by rewiring it, but the side airbag wont work, unless you get the srs control mudule and harness for the 02-03 then youllhave to switch out your front airbags because the 99 is single stage as the 02-03 is a two stage airbag. Or you can just leave it and not have the side airbag like me.
Originally Posted by myron
what is the difference in the seats? I thought only the head rest is different.
I know its possible. Someone did it already, SRS should be the same, but the seat harness is different. Someone also put in CL-S seats
Originally Posted by fsttyms1
Seats are different. perforated leather, firmer, different bolsters.
that's right, thanks kris.....
I know that the seat wiring harness id differefnt for almost every year. the 99 only has like a 8 pin connector and the 02 has a blue 15 pin connector and the 03 has 18 pin connector. the 99 didn't come with side air bags, so we won't be able to use that function of the seat. but hell, anything is possible. like kris said we put 6 speeds in, a seat is childs play.
by the way kris...... still waiting on those notes from the wiring you did....lol....whenever you get a chance.
He cut the shifter height down. The only short throw doesnt make the shifter height shorter.
Originally Posted by Napsoner
I love the look of a shorter shifter. I didn't do a 6speed conversion, but what would I have to do to cut down the shifter. I plan on doing a 6speed conv in the near future though.....
when I had the auto I cut it down and didnt have to rethread it or reweld it . I just cut about an inch off, but made sure that i was still able to get down into first with gate shifting...
Yea, With the auto you can just cut off a 1/2-1" or so. The threads go down pretty far. You cant cut too much off or when in shifted down to1st the shift knob will hit the shift gate.
On the seats some of those pins must relate to the memory seat. I have to check what the 2000 has and I can post the pins for that model. I am sure its close to the 99 but the extra would be the side airbags. Did the first years of the CLS have memory seats?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
