LED Daytime running Lights
I want to put LED daytime running lights on the front of my 2003 Acura TL. I have already put the lights in place, i just need to wire them now so they will work when the car is on. I am thinking about wiring them to the radio, but I'm not sure if that will work. Has anyone done this before and if so can you help me out on how you did it? if not any help or suggestions would be appreciated
MechEng
i use my fog lights as daytime running lights ![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
do the fog light mod, and wire them to the fog lights.
fog light mod:
https://acurazine.com/forums/2g-tl-1999-2003-98/fog-light-mod-alternate-version-549015/
taken from DIY thread:
http://www.acura-cl.com/forums/showthread.php?t=706083
if you don't want to go through that (although trust me, it is very easy), wire them to your cig lighter.
fog light mod:
Dont connect it to the radio, connect it to the back side of the drivers side fuse panel. There are 4 spots to hook up to. 1 is switched, one is when lights are on and 2 are constant.
I thought about wiring to the the battery with a switch but that would kind of defeat the purpose cause I wouldnt want to have to turn them on every time. I am thinking about either the cigarette lighter or radio cause those i feel like might be the easiest since i have the passenger side panel off under the radio/middle console. I have an after market head unit for the radio already in so wiring to radio would be very easy, but i may take a look at trying the fuse box on drivers side
mada51589
05-03-2022 08:54 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
