AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   2G TL Performance Parts & Modifications (https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/)
-   -   interchangeable parts? (https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/interchangeable-parts-875489/)
Stephen Singh Dec 8, 2012 11:29 AM
can anyone tell me which tl's can interchange suspension parts? i have a 2000 tl, non type s, its in great shape and it seems pretty easy to find suspension parts for other tls.
jjashaa Dec 8, 2012 12:53 PM
99-03
3.2TLc Dec 8, 2012 01:05 PM
Acura 3.2 TL, 2nd Gen. models: ~'99>'03~
Hey Stephen Singh, welcome to Acurazine !
If you need any spare parts, check out the "Black Market" sub-forum for new and used items of all sorts for our TL's. If buying "used" suspension parts, be careful of the condition due to wear. Oftentimes considering the effort involved with labor, it's wise to purchase "new" parts in my opinion. :2cents:
If your local auto salvage recyclers have any '99 to '03 TL sedans, the parts from them will all interchange with your 2000 model. The exception being that the '99 has a slightly different drivetrain, mainly due to the older 4 speed AT.
There's a ton of 2nd Gen TL's out there with bad trannys, but with all sorts of good parts. The "S" model's suspension is upgraded, but with some extra effort should work. Some other options are the Acura CL 2 dr coupe, which shares alot of drivetrain / suspension parts with the TL sedan and lastly some of the sister Honda Accord V-6 parts, especially with the newer improved tranny's being an excellent donor for our TL's.
fsttyms1 Dec 8, 2012 01:20 PM
All 99-03 TLs use the same suspension.
03tLsNBP Dec 8, 2012 02:30 PM
these suspension parts will interchange between 99-03 TL, 01-03 CL, and 98-02 Accord:
strut tower bar
front camber kit
rear camber kit
front sway bar
rear sway bar
springs
shocks
full coilovers
these suspension parts will interchange between 99-03 TL, 01-03 CL, 98-02 Accord, and 04-08 TL/TL-S:
rear sway bar
anyone is free to add to this list.
HairyMonkey019 Dec 8, 2012 04:25 PM
does anyone know if honda odyssey or accord airbags fit the 2g tl?
Stephen00TL Dec 8, 2012 04:53 PM
If I remember correctly 6g accords, can't remember the year mdxs, and not sure about odyssey
Johnathin Haman May 7, 2018 04:39 PM
99 Acura TL
I have a 99 Acura CL and I also have a 2000 Acura CL I'm wondering if I can interchange the Transmissions between the two I'm trying to put the 2000 transmission into my 99 is that possible
Chojun May 8, 2018 09:57 PM
Is the '99 a 4-speed? If so, then no. Not without major work.
© 2026 MH Sub I, LLC dba Internet Brands
