HID lights
06 NBP 6MT TL
Most reliable, or most reliable on a budget? TheRetrofitSource will be the most reliable out of the stuff people will recommend on here (HIDextra, DDM, etc) but it is a bit more expensive.
For fogs you could run a DDM/HIDextra kit and be perfectly content. I would advise against putting HIDs in the high beam, because it is a waste. HIDs need time to warm up, and unless you're running your high beams on for extended periods of time, it will be worse than your halogen bulb.
The following 2 users liked this post by cincinattlguy19:
coronaman (04-07-2014),
justnspace (04-07-2014)
The kelvin is a http://en.wikipedia.org/wiki/Units_of_measurement for http://en.wikipedia.org/wiki/Temperature. It is one of the seven http://en.wikipedia.org/wiki/SI_base_unit in the http://en.wikipedia.org/wiki/International_System_of_Units (SI) and is assigned the unit symbol K. The Kelvin scale is an absolute, http://en.wikipedia.org/wiki/Thermodynamic_temperature http://en.wikipedia.org/wiki/Scale_of_temperature using as its null point http://en.wikipedia.org/wiki/Absolute_zero, the temperature at which all thermal motion ceases in the classical description of http://en.wikipedia.org/wiki/Thermodynamics.
![](http://www.cinelight.com/images/articles/kelvin_scale_color_temperature.jpg)
in laymans terms; the higher you go on the Kelvin scale, the more blue or purple the color is.
HOWEVER, and it is a big HOWEVER, the Higher you go on the Kelvin scale, the less Lumens the light produces.
this means, if you do a lot of highway night driving, you'll want to stay with the OEM factory Kelvin temperature bulb. as 4300Kelvin produces the MOST usable light
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
We got 4700KV as OEM which is AMBER and got around 3500-3700lm
on Contrast most just go straight to 5000K which is Ultra White and has a rating of 3400-3600lm.
Any higher and it starts to lose brightness or Lumens but the real Issue is that the light color starts to shift into a darker tone which blends into the roads so even if it has a brighter rating than halogen since its a darker Hue it seems like it has way worse rating well below -1000lms...
6000K = Soft white/Blue = 3300Lm
8000K = Polar White = 2900-3000Lm
From here it shifts into Darker Hue so they are illegal and recommended for show purposes only.
10000K = Light Blue = 1900-2100Lm looks like 1100-1500Lm
12000K = Ultra Blue = 1100-1700Lm looks like 500-800Lm
18000K = Purple = 500-1000Lm looks like 100-300Lm
Stock Halogen Bulb High Beam = 1700Lm.
Stock Halogen Bulb Low Beam = 1100Lm.
The following 3 users liked this post by Skirmich:
^^ You gotta look RED HIDs (Something like 35,000KV) they don't even bright up anything!! its just a tone of red that you cant see more than 3-5 meters away..
justnspace (04-08-2014)
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
BoricuaTL
04-08-2016 01:08 PM
