HELP! dc sports header install
I own a 2003 CLP and the rear motor mount seems to be stopping me from aligning the rear header with its studs. I've read in other posts that one can remove the rear mount to install the header but is there a way to install the header without actually resorting to that?
Chapter Leader (Southeast Region)
I am pretty sure from what I have read that you have to remove the rear mount to install them. Hopefully they work out well I am probably going to be ordering the same ones in the next few months.
Oakroadsteve (02-15-2012)
yep, mount needs to be removed.
We did not document the process or the finished product yet. It looks sweet though.
Taking the studs off is cake. You just put on a couple of nuts on the stud and take a wrench to it and they come right off. We had it on a lift and had a transmission stand at the ready for the motor mount removal just in case.
You can take the studs odd when you remove the stock manifolds. This is probably the way to go if you are going to jack the car up and use jack stands...
Stephen00TL (02-16-2012)
it takes about 2 min to remove the mount
TLDude876
12-28-2016 03:18 PM
