Headers with stock exhaust
So I sold my tanabe catback and might be picking up a set of XS Power headers to bolt up to my stock exhaust...
My questions is, will I feel the gains even with the stock exhaust? Or am I better off not even wasting time on the headers?
I"m also planning on gettting the UR Stock Sized Crank pulley too just to free up some hp
Unregistered Member
The Type S cat is a little bigger than the TL-P cat, right?
I'm considering getting a test pipe, or putting in a Type S cat. Are there any side effects to using a test pipe (other than not passing emissions). I understand the exhaust will smell bad, but will it damage a catback? I don't want to mess up the catback I got coming in soon.
I need 2 more gears
You will feel and see gains from just headers. I see you have a CAI and thermobloc spacers so the difference will be much better. Our stock exhuast flows well out of the box, but the CAT is the next biggest bottleneck. I'd get a Random Tech Hi Flow Cat. Excelerate has 2.5" in/out ones now. I have an older 2.25" in/out one and it's much better than stock 2" in/out. A Catback will give you a little extra at the top of the powerband, but that's it. You will not feel it at all otherwise. The sound though is everything!!
you will feel gains up top. your exhaust will sound a little pingy because there is a lot more air going through them, so aftermarket or custom exhaust with a 2.5" cat as well is the ultimate set-up. xs collector 2.5" then get 2.5" cat, then 2.5" piping for the exhaust...no resonator or mid muffler either, with some bigger sized mufflers and your good to go with no raspyness or vibration and an aggressive sound with good top end power...Xs headers buzz around the collector though, so dont be alarmed by that
Former Sponsor
DC Sports makes a great header also for the CL/TL Auto.
http://store.excelerateperformance.c.../i-130510.aspx
We have those in stock.
You will still see plenty of gains from the headers alone.
What size piping should i get with headers and stock mufflers? I have a single magnaflow( sounds Like a civic) that im replacing with the stock mufflers in the morning. I'm getting headers soon and want to keep the stock look so just curious what size piping is best. Thanks
I am going to finally install my headers after i get home from my job in 2 weeks but I do want some noise so i was gonna do a midmuffler delete and i was curious as to what mufflers will give a bit of a G35 sound and good gains for a decent $$$$ I checked as well i do not have a stock resonator on my tlp
takin care of Business in
Received 4,732 Likes
dude the headers will give you gains but I would go ahead and get exhaust as well....
the reason I say so is your are opening up the headers but them putting a restrictive exhaust so your engine is working extra hard to push that air out...
so you will feel the gains but not the full thing....once you put the exhaust it will complement the headers giving you more gain...
mrkingstonvi
02-22-2016 01:53 PM
joflewbyu2
10-08-2015 11:16 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
