Cat Delete/Straight Pipe Q? re sensors
Old Feb 7, 2010 | 03:03 PM
oulaw29's Avatar
Attorney- Will Sue 4 Food
I searched the threads but still a lil confused bout using a straight pipe. The shop doing the work on my TL now says they can fabricate a straight pipe, but I am going with an OBX since i am in a time crunch and want to make sure I dont want to run into issues with wrong fit or cost overrun. What if anything must I get to avoid throwing codes with the cat delete? I'm in a crunch i need to get the parts by friday so need to order by monday.
Old Feb 10, 2010 | 07:09 PM
reese8789's Avatar
you can put a spark plug non fouler in the hole were your oxygen sensor is. Then screw oxygen sensor in to this so it will be out of the direct exhuast flow. This should stop the check engine light from coming on.you can buy these from autozone for like 3 dollars .Just make sure its a long one and same size thread or else the oxygen sensor wont fit in it.
Old Feb 10, 2010 | 09:08 PM
ANC297's Avatar
Bonki' Ehrite!
Exactly...This is more or less the only way for custom made straight pipes...
Old Feb 11, 2010 | 09:10 AM
fsttyms1's Avatar
You will have to have a O2 bung welded into the test pipe to do this though.
Old Feb 11, 2010 | 02:50 PM
gfrg88's Avatar
slow tl..
obx makes test pipes for our cars??? I thought only p2r had them....
Old Feb 20, 2010 | 12:57 AM
oulaw29's Avatar
http://www.obxracingsports.com/products.php?pk=838
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
DerrickW
Nov 15, 2015 05:52 PM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
thegipper
Sep 28, 2015 01:01 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
