Best way to Black out your Tailights?
i want to black out part of my taillights, whats the best way to do this?
vvvv kinda like this vvvv
but id leave the clear top part of the lights untinted. Anyone have pictures?
silversurfer99 (01-17-2012)
I agree with ....Too dark for my liking..
I did a very subtle tint on my tail lamps. Sanded them down and then
added a few drops of black to the clear coat before spraying them.
KatabaticSaint (10-13-2011)
This was exactly how I had mine and I loved them but after getting pulled over 2 times one day I removed it.
If I can give the op some advice DO NOT use vht niteshades it goes on great the 1st time looks awesome but it fade in a year and if you try to take it off it will ruin your taillights a 5 dollar can set me back 150 for new taillights but some sort of lay if you're set on this.
Damn. that sucks but i thinki might just not tint them at all.
I did to my black acura like the white TL above did, blacked the red left the white, looks clean. I used tint and had them done at a local tint shop, this way its removable at will
Did mine with film. It's looks great and can change or removed them whenever i want. Was thinking of spraying them but the thought of it being permanent was what made me go film.
I would be careful of using sprays. Preparing for paint usually would require sanding/scuffing or at least a harsh solvent to get desired effect.
Also aren't Floridas laws a little more easy on tint and such?
I took out my tail lights, cleaned the surface real nice, and then used night shades (the spray). if you have a steady hand and fluid motion while applying the lights should turn out great. Just have to make sure you do a good job! luckily if you fuck up it comes right off with some goof off.
Vandy63 (01-30-2012)
How much do you think it would cost if I got my tail lamps tinted with film from a tint shop? Im not looking to go really dark, just as dark as Mr. Maker's TL up there ^^
buy some film and DIY, it's very easy. I run a tint shop up here and the cost of the film isn't expensive. Some shops around us charge any where from 60-100 bucks. Film cost lest then that and just DIY and trim the excess
Illest144 (02-15-2012)
Thanks, where would I get the film from? And if I just wanted the "smoked" look or just barely tinted like mr. maker's which percent should I use?
JDM96specCTR
10-17-2015 01:06 PM
