any tl 2 steppers?
any tl 2 steppers?
check this video. its a evo 2stepping. has anyone install this kit on their tl? if so post vids or pics. also what is everyones thought on it.
http://www.youtube.com/watch?v=8__18txcEiA
Mr. 2tone
um...hope u know 2stepping doesnt let u shoot flames out ur xhaust
its for launch
ive looked into it b4...msd ignition...
after a lil looking around i thought its pretty pointless to put into a TL
its for launch
for me its not really about the flames. i understand you need power behind that. but i like the POP it makes.
check this video at :34
http://www.youtube.com/watch?v=OxwHLibjQp8
B A N N E D
x2
but some people don't have a cat though, but yeah it can damage stuff like that, if on a pretty stock car though
let alone wasting gas
but yeah i don't see why the driver is revving it so much at idle just sitting there, not like they are going anywhare, with the car in front
and sort of ... but this is a kit u install in ur pipe... it doesnt mess up the cat... it goes after that.. build up air in a coil den lets it out makin that pop.... its a launch control system...
my question again is.. has anyone done it? on any car?
B A N N E D
yea its JUST a tl....old one at that... ..
why in the hell would you want your car to do that? what do you think this is fast and furious? like your cars some gay ass ricer, That is pointless and would look sooo dumb on a mild four door family sedan. idk maybe you mexican???
Mr. 2tone
in order to have 2step u need an ignition control box...which is a computer module...then u need a 2step module...which is another computer module(rev control)...then u tune the 2step module...then u have 2step...
does that something u "install in a pipe"?
Mr. 2tone
found instructions for a flamethrower kit on google...read step 2...
INSTALLATION (dual exhaust is next )
1. Mount the control box in a dry location where it won't be disturbed. Under a front seat or in the trunk are popular locations.
2. Install the spark plug(s) 3 to 6 inches from the end of the tail pipe(s).
3. Follow the wiring diagram above to wire up the system -
• FIRST - Disconnect the battery
• Yellow wire from control box goes to one switch connection.
• The second switch connection goes to the positive terminal on the battery
• Wire from positive battery terminal to the fuse and from the fuse to the green wire coming out of the control box
• Black wire from control box goes to ground
• Connect red wire to the positive terminal on the ignition coil
• Ground the coil
• Run spark plug wire (or make your own using 4G or 6G wire) from the coil (center post) to the spark plug. Make sure the spark plug is grounded. TEST for spark without the engine running.
• Ground the coil
B A N N E D
• Ground the coil
• Ground the coil
3.7L Nitrous Breathing CL
I was curious about this about a year ago,and was turned away thinking it was only for turbo'ed cars.
This is what first made me interested.
http://www.youtube.com/watch?v=ikrajw8nWUU
2steps are awesome on high power, boosted applications. My lil bro has it on his evo and at the track its 17psi of boost off the line.
:jedimindtrick: (waving hand) you don't want this on your car
