Another Dyno result with DC header
291hp & 245 tq @ 3.5psi
I just finish the dyno today. The result is very similar to LudetypeSH.
max power= 230.1
max torque= 192.46
So with AEM CAI instead of Ice box, and thermoblock spacer, LudetypeSH's car has 2 more power and 5 more torque!
I'll post the graph later on tonight, but it looks almost exact the same as the one LudetypeSH posted. The air/fuel ratio is at 12 from the beginning up to around 5.2K rpm. It went down to 11 from 5.2K to 6.2K. Above 6.2k rpm, the air/fuel ratio is back up to 12. Don't really know what it means. Need to do more research tonight. Any thought on this air/fuel ratio thing?
max power= 230.1
max torque= 192.46
Nice numbers....LacViet...how many pulls did you do? I wanted to do a 4th pull but the shop was closing. I also wanted to wait 30-45 minutes in between pulls so that my car could cool down. I might have been able to pull a little higher numers (approx. 1-5 whp) if my car was cooled down...according to the shop. Where did you end up dynoing your car? Thanks.
Here's another dyno sheet with my 2 highest runs on 1 graph:
Nice #'s. That difference could be any thing from dyno type to weather.
LudetypeSH: I had dyno at the same place you did: Dyno Extreme. I did 3 runs total with one right after another. The first two runs are almost identical with max power=224 and max torque=189. The last run is the highest of the three. I'm happy with the number!
Here is the dyno sheet with all three runs:
and the best run:
and the best run:
Lac Viet...that's still a good number...your engines output is about 302bhp. I'm sure that's what Dyno Extreme told you. Did you see a Blue Supra there? If you did, that's my bro-in-law's car and he is getting ready to sell it after restoring it a bit. Only problem is that it is a automatic...I'd jump on it if it were a six speed.
I have to bring my car back to the shop that installed my Header and spacers....I hear what sounds to be an exhaust leak...hopefully it isn't. I need a second opinion though. The shop is down the street from Dyno Extreme and located on Dale and Katella. The shop is called Quiken Motorsports and they specialize in Honda/Acura. If you need any other stuff installed...I would recommend them.
Duy: Are you gonna go to the meet? Haven't seen you at the meet for a while.
I paid the same price. With air/fuel ratio is another $15.
a/f look pretty good. do u see that red dotted line, thats the line they try to aim for while tuning. altho u didnt get tuned, just some pulls, ur a/f look good considering just having bolt on. ur still a little rich. that red dotted line is stoic. u dont want to be above the red line which equals bad.
as for dyno #'s, definitely need to ask this dyno place for a dyno graph w/ zero SAE corrections. those are more meaningful.
ill try and explain the best that i can because im no expert and far from it.
as for ur a/f ratio it may need more air and/or fuel. u need equal amounts of both if u want to make more power.
as for the SAE smoothing, u could change it ur self but the graph would remain the same.
the dyno guy must change that number for it to take effect on the graph.
Sippy Cup (x2)
Nice #'s. That's almost exactly what my AFR looked like. Dropped down in the same spot and everything. I wonder if that has anything to do with VTEC. I don't think I am gonna go with the VAFC yet...maybe sometime down the road.
As for the SAE correction....what the heck does it mean. Mine said SAE:3
Former Sponsor
Originally Posted by Excelerate
Before VTEC is about to engage the ECU starts dumping extra fuel to compensate for the amount of hp about to be created. Once VTEC engages you are operating on a different lobe on the camshaft which is more aggressive than the other lobes. Therefore more air will be flowing in and therefore you need more gas to make more power. So basically the fact that the AFR dips is normal. You will rarely be able to eliminate that dip. And besides on this car there are virtually no gains to be had by playing with the AFR. It has been tried by other members. The Honda Map is perfect.
AND HOW MUCH?? lol
Sippy Cup (x2)
Originally Posted by Phesto
what about that Apexi Neo AFR regulator??
AND HOW MUCH?? lol
AND HOW MUCH?? lol
Thanks for the info Josh...I don't think that I'll be picking up the VAFC, it's just not worth the money.
Side note, I may stop by this weekend to pick up some rotora rotors and pads for my 02 TL if you have them in stock. I'll check the website to see when you're open. Only if I have time though, I'll be doing quite a bit of running around. Otherwise, I'll be ordering them within the next couple weeks.
It also interesting that by changing different Correction factor such as: DIN, EEC, STD, JIS, or Uncorrected, the dyno graph shows either gain +3 horsepower (STD), or lost -15 horsepower (uncorrected). It's totally confusion. Anyway, it's just a tool to help us gauge the improvement of the new mod!
Here is the dyno with SAE smoothing = 1
and here is the original dyno with SAE smoothing = 5
exactly, dynos are just a tool to gauge if the mods really add any HP.
uncorrected graph is what u really want to look at. of course, dyno shops will not do uncorrected since the numbers look less impressive.
the only truly way to gauge how much power u make is do some 0-60 runs and 1/4 mi runs to determine ur trap.
Lacviet, could u post ur uncorrected graph.?
Originally Posted by cheezwerkz
just got my apexi afc neo install yesterday and will be gettin the car dyno on tues at xs engineering. so i will let u know how it go
btw, are you coming to the meet?
Sippy Cup (x2)
i am looking for a good place in the bay area to get my apexi neo installed,any help ??
bump from the dead...
im really interested in seeing if there are any gains to be had by tuning and leaning out some. even if there isnt much power to be had... you could definetly get better mileage.
Former Sponsor
There were a few members a couple years ago who installed and played around with the settings with the Apexi VAFC and they actually lost power. Honda had it right from the beginning so don't waste your money.
6G TLX-S
any chance the results are still around somewhere? im not doubting you, and im sure anything is possible... its just weird that "correcting" the afr would result in a loss of power.
For a highly factory tuned engine, the factory Honda air/fuel ratio map is really fully optimized (or already "correct" in your words). So any messing around with the AFR map values will only "uncorrect" the optimum setting and results only in reduced engine output.
but just ouf of curiousity... if someone does have a dyno that has been vafc tuned, i would like to see it. just wondering what kind of results came from changing the afr.
on a sidenote, guess i just saved myself almost $500, since i apparently wont be needing a vafc/pnp harness.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
